Rear tail light issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glennv, Apr 20, 2022.
  1. Apr 20, 2022 at 9:39 AM
    glennv
    glennv [OP] Well-Known Member
    My passenger side taillight does not work. The center LED works fine as a brake light but when I turn on my lights the left is on but the right isn't. Both work fine when braking. Check fuses and nothing however the issue is only on one side anyway. Any thoughts? It's a 2009.
  2. Apr 20, 2022 at 9:45 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    A 2009 Tacoma uses dual filament bulbs in the tail lights. Sounds like your running light filament is burned out, but the brake filament is still good. I believe the bulb is a 3157.
    b_r_o likes this.
  3. Apr 20, 2022 at 9:54 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Unplug them both and swap them, yes they will not fit but this will verify that if it is the light or the wiring
    b_r_o, eherlihy and Dm93 like this.
  4. Apr 20, 2022 at 10:22 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    get a voltmeter out to check for voltage at the connector with lights on.
  5. Apr 20, 2022 at 11:15 AM
    Too Stroked
    Tom
    Hmmmm. For some reason I thought the early 2nd gens had incandescent tail lights. My bad.
  6. Apr 20, 2022 at 2:35 PM
    glennv
    Good idea. Just did it and it works fine....so that means I have a bigger problem on my had. What now?
  7. Apr 20, 2022 at 2:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like you aren’t getting power to the tail pin of the plug. (Green wire)
    The Stop and Tail use the same pin for ground.
    TRDSport10 and Dm93 like this.
  8. Apr 20, 2022 at 3:00 PM
    glennv
    So power is the green and the ground is the white/black wire? Thanks. And the switch behind the brake pedal wouldn't have any impact on the tail light would it? Brake light works fine.
  9. Apr 20, 2022 at 3:06 PM
    TnShooter
    Deogee
    STOCK
    No, that switch shouldn’t have anything to do with your problem.
    If for some weird reason it did, you expect to see it on both tail lights.
    Do the license plate lights work?
    Dm93 likes this.
  10. Apr 20, 2022 at 3:15 PM
    glennv
    Yes both sides work. I'll have to get underneath it tomorrow. I did back into something months ago and bent the bumper a bit. Bent it back out but maybe I damaged the harness somewhere.
  11. Apr 20, 2022 at 3:42 PM
    TnShooter
    Deogee
    STOCK
    That’s possible.
    The power for both the tail and license plate lights come from the same place.
    The are spliced in for each light.
    Dm93 likes this.
  12. Apr 20, 2022 at 4:28 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    I just fixed a Tacoma like this at work, the left taillight was not working, but brake light was. Just as @TnShooter said, the green wire is power for the taillights and license plate lamps, and on the truck I was working on, the green wire was corroded about a foot back along the harness, where the insulation was rubbed thru. Thankfully, it was a simple fix, but do a visual inspection of the harness, and if something doesn't look right, take a second look there.
    TRDSport10, Dm93 and TnShooter like this.
  13. Apr 20, 2022 at 4:44 PM
    glennv
    Thanks for the info. Does the harness run from front to back or does it run across the rear and then up the drivers side? Thanks
  14. Apr 20, 2022 at 4:48 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    2005-2008 has incandescent 2010-2015 are fast and the furious lookin' LED's.
    TRDSport10 likes this.
  15. Apr 20, 2022 at 5:18 PM
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    The main harness goes down the frame (on left side of truck), gets to the rear bumper where it splits off to the left side light assembly, then turns right down the rear most frame crossmember to the right side light assembly (and a couple branches to go to the license plate lights).
    TnShooter likes this.
  16. Apr 20, 2022 at 7:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Harness routing and wiring diagram if you need it.
