Rear tail light issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Akeela1995, Apr 27, 2023.
  1. Apr 27, 2023 at 11:11 PM
    Akeela1995
    Akeela1995 [OP] Active Member
    1995 Tacoma
    Hey everybody!
    My rear driver side tail light used to just be dim. And randomly only some times my left turn signal would stop working when I’d press the brake.
    Now it seems to not be dim anymore. My new issue is that the same light (driver side tail light) doesn’t stay on as a running light, instead, my turn signal light stays on. And when I turn my left turn signal on my turn signal and brake light flash but not even at the same time!
    Would this be a ground issue? If so, where would I find the ground? Or something different at play?
    I don’t know much when it comes to electrical so any and all help is appreciated!!
    Diagram and pictures are my best friend hahaha
    Thanks in advance!!! :)
    PFA
  2. Apr 28, 2023 at 2:53 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I would start with cleaning all the sockets with a fitting brush in a drill .
    I use CRC 556 in the socket to remove corrosion and help keep it from returning.
    Do the front as well ,\.
    New bulbs or clean the metal parts as best you can.
    Then see what your dealing with.
    All the bulbs ground through the sockets.
