Rear tire and fender distance not even.
Discussion in '1st Gen. Tacomas (1995-2004)' started by kulrajg, Apr 17, 2014.
  1. Apr 17, 2014 at 2:28 PM
    kulrajg
    kulrajg [OP] Well-Known Member
    Arleta,CA
    blacked out.
    As i was walking to my truck today, I noticed the right rear side was little higher than the left rear side. Then i measured the diastase between rear tires and fenders. the right side was more than 2 inches higher than the left side. And the truck was parked on even surface. and nothing was loaded in it. Does anyone knows what it can be? Thanks!
  2. Apr 17, 2014 at 2:43 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    It's the taco lean pretty common
  3. Apr 17, 2014 at 2:45 PM
    kulrajg
    Arleta,CA
    blacked out.
    is there any way to fix it? or it's just a normal thing?
  4. Apr 17, 2014 at 4:29 PM
    BAMFTACO
    Juan
    Kings bruh
    what people do is add a quarter in spacer to the front left and usually helps with the problem. you can order it on the wheelersoffroad website or toytec
  5. Apr 17, 2014 at 4:31 PM
    BAMFTACO
    Juan
    Kings bruh
    how many miles are on your shocks worn coils and shocks could do it also
  6. Apr 17, 2014 at 5:05 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    I don't know if this is the extent/cause of your issue, but tacoma rear springs actually have different specifications/rates, to counteract driveshaft torque.
  7. Apr 17, 2014 at 5:13 PM
    oldracer
    oldracer Well-Known Member
    Tell us how many miles on it:
    Is the front worse than the rear or vice versa?
    Of course, check tire pressure, and measure on a flat surface.
    Is it all stock, from the factory?
  8. Apr 18, 2014 at 7:01 AM
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Yep taco lean.
    Stock shouldn't be that bad, sounds aftermarket.
    You'll notice it much worse with a full tank and any weight in the back with no passenger.
    I've got a Deaver j66
    Installed and it had a full two inch lean so I took it back. They arched it up more and added an eleventh leaf to it
    A month later, same shit. Full 2" taco lean.
    But she rides like a caddy off road and that's all that matters.
    It won't really affect you much other than looking wrong to the discerning eye.
  9. Apr 18, 2014 at 10:01 AM
    kulrajg
    Arleta,CA
    blacked out.
    it has about 110K miles on it. and everything is stock.
    the tire pressure and shocks and coils are fine too.
  10. Apr 18, 2014 at 8:40 PM
    Spencer
    TIGGLEBITTIES
    Yeah you're prolly due for leafs at this point then. Not sure why else that'd happen but 110k on springs that are already soft and at nearly zero arch when brand new stock ... They're just old id say
  11. Apr 18, 2014 at 8:56 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    I also had this issue. It got better when i changed the rear shocks and leafs but its still uneven. heck....my whole truck is uneven. wierd thing is that my passenger side is lower then the driver side with the rear. and in the front, the driver side is lower than the passenger side. drove me nuts for a long ass time so i changed everything. it helped but still uneven all around. when i look out my rear view mirror, the tailgate aint even either....passenger side sits lower then the left. i use the bottom of the rear window as a guide and i can see its not a straight line when looking at my tailgate. at one point, i almost got rid of my tacoma because of it but decided to just deal with it. supposedly its somewhat common, especially with older years - mine is a 99 with 216k.
