Rear Tire wear problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06SUPERWHITE, Nov 6, 2011.
  1. Nov 6, 2011 at 6:13 AM
    06SUPERWHITE
    06SUPERWHITE [OP] Member
    Carl
    Barrie Ontario Canada
    06 Access Cab SR5 3" lift
    3" lift after market rims 285/75/17" tires dual side exit cat back exhaust, k&n cold air,
    I have an 06 Tacoma 4x4, with a 3" spacers in the front and 2" angled blocks in the back. I had all the work done this summer and also but on 285/70/17 on after market rims, I recently took the aftermarket rims off to put on my winter rims with 16" tires (tires are new) and noticed that about about 1/2" of the outer part of the tire had some excessive ware, and the center and inside of the tire where fine. I thought maybe it had to do with the tires or the fact the offset of my rim was different, and was going to deal with it in the spring. Now that my winters have been on about a week, im already starting to notice the same thing.
    Any suggestions? My understanding is that there is not adjustment for camber or toe on the rear, and it is happing to both rear tires.
    Thanks.
  2. Nov 6, 2011 at 6:21 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    have u rotated tires lately. no adjustment on rear
  3. Nov 6, 2011 at 6:24 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Sounds like your running low tire pressure in the rear.
  4. Nov 6, 2011 at 6:25 AM
    06SUPERWHITE
    Carl
    no rotation tires are new, have only been on truck about 500kms, it is very slight, but can see it is starting.
  5. Nov 6, 2011 at 6:31 AM
    06SUPERWHITE
    Carl
    Would this not show the same sort of ware on the inside of the tire as well? The only ware is on the outside 1/2" of the tire tread.
  6. Nov 6, 2011 at 6:40 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Yes, you're right. I misread.
  7. Nov 6, 2011 at 7:00 AM
    cc350
    cc350 Retired Member
    Maybe you need to take it in for a 4 wheel alignment, maybe the rear end is out.
  8. Nov 6, 2011 at 7:12 AM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Was this in an accident at one time ???
    Had a 2wd with what you are indicating. had 3 alignments at different places.
    got dropped in my lap.
    did a alignment check
    Thrust line was way off and rear toe was way out. Rear end got tweaked and was wearing the crap out of the tires. Had to replace the rear housing.
    i would do as suggested and have a alignment checked and printed out.
    Then we can see if the truck is square or not.
    Have to start somewhere and this is the way to go first.
  9. Nov 6, 2011 at 7:38 AM
    06SUPERWHITE
    Carl
    no accident that i know of, nothing on car fax, had truck a year and a bit, think i will make an appoinment for 4wheel allignment, didnt have any problem before i did lift...
  10. Nov 6, 2011 at 10:07 AM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Good.
    Have them look real close at the thrust line then.
    If this is the case you might have to double check the install of your lift.
    I'll be real curious on what they find.
    Something isn't adding up.
    Good Luck
  11. Nov 6, 2011 at 12:39 PM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    I would re-check your lift. Make sure both blocks are installed in the same direction (the angles are both facing the same way), the center pin on the spring is properly seated in the block and the block is properly seated on the spring perch. May have to loosen your u-bolts to make sure you haven't sheared a center pin on your springs, or a locating pin on your blocks.
