rear tire wear???
Discussion in '1st Gen. Tacomas (1995-2004)' started by easye530, Nov 14, 2014.
  1. Nov 14, 2014 at 10:16 AM
    easye530
    easye530 [OP] New Member
    my rear tires are rubbing much faster on the inside of the rear tires. by inside i mean closest to the center of the truck not the center of the tire...and ideas? :rolleyes:
  2. Nov 14, 2014 at 11:11 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    hmmm, never heard of a bent rear end housing before but that is the only way I can think of it being able to be riding only on the inside edges of the rear tires, if both bearings were that bad im sure the axles would be leaking
  3. Nov 14, 2014 at 11:14 AM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Could be worn rear bearings allowing for added camber. How many miles on the truck?
    you could jack up the rear axle and see if the camber becomes positive or if you can find slop in the bearings up and down.
    Might be causing a toe out when driving as well, increasing the wear faster.
  4. Nov 14, 2014 at 11:58 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Maybe they got worn while on the front due to an alignment issue and not apparent until the overall tread depth got lower allowing more visual contrast. Do you rotate the tires?
