rear tire wear!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Jun 12, 2020.
  1. Jun 12, 2020 at 11:59 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    tires were 9/32" but recently found the rears to be at 6/32"
    how!?!?
    These tires were supposed to last forever!
    How does one even check or adjust rear alignment given that supposedly it's fixed with no adustment points?
    06Tacooo likes this.
  2. Jun 13, 2020 at 4:58 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Alignment issues are not the only thing that can cause uneven front to rear tire wear. Under (or over) inflation, overloading, hard cornering and plain old poor tire design and manufacturing come to mind as just a few possible reasons. Before you try to re-align your (non-adjustable) rear axle, how often do you rotate you tires and check inflation pressures?
  3. Jun 13, 2020 at 5:03 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    How often are you rotating them?
  4. Jun 13, 2020 at 7:08 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I hope this is sarcasm.
  5. Jun 13, 2020 at 2:34 PM
    TacoTuesday1
    FL
    There's supposed to last a lot longer than 5,000 miles. They have a mileage warranty from the manufacturer for 60,000 miles, assuming you stay on top of air pressure, rotating, and alignment. Which I do.
    Every 5k oil change.
    Most often once a month because more than that the PSI doesn't really deflate unless there is a puncture, which TPMS lets me know. Already had that once; it was a slow leak. Quickly found the nail and patched it.
    Keeping it at 29 cold psi according to the door sticker/manufacturer suggestion.
    Even though the rear is marketed as non adjustable due to not being a multiple control arm layout with camber and toe adjustment bolts,
    it still can probably be adjusted by loosening and moving the U-bolts.
  6. Jun 13, 2020 at 3:17 PM
    Too Stroked
    Tom
    Not exactly. There's a pin in there that pretty well prevents you from moving the axle. Trust me, unless your truck has been in a pretty serious accident, the rear end should not be out of whack.
  7. Jun 13, 2020 at 3:26 PM
    TacoTuesday1
    FL
    ok thanks
    I'll see if I can throw it on an alignment rack just to check
    or another way I've found to get an idea is using sewing string on jackstands to make a square around the vehicle, and measuring in with a ruler to wheel center cap and left/right rim edges to know if it has excessive toe
    Hasn't had a serious accident didn't know if it's something that off-roading can throw off, without really good shocks to soften impacts
  8. Jun 13, 2020 at 3:39 PM
    Too Stroked
    Tom
    You don't want to check alignment with the vehicle up in the air on jack stands. Your front suspension will be at full droop and thus your numbers will be way off. If you want to string measure it, do it on flat ground with the vehicle at ride height.
  9. Jun 13, 2020 at 4:29 PM
    TacoTuesday1
    FL
  10. Jun 13, 2020 at 4:39 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    red LED lights at Lowes/home depot are easily had
    relatively cheap
    used inside a darken garage true straight line is easily determined
    rock crawling/muddin/the occasional ditch can throw a rear end out
    'toe end ' doesnt always show bad tracking
    good luck
  11. Jun 13, 2020 at 5:16 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I agree you shouldn't be going through tires in 5,000 miles with normal driving.
    What tire, size, and load rating are you running? Do you have even wear across the tread? What shocks and how old are they?
  12. Jun 13, 2020 at 5:42 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Part of this was going to be my first question, are they wearing evenly across the tread?
