Rear, transfer case and front differential oil change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Morbid250, May 4, 2023.
  1. Jul 25, 2024 at 9:22 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    i had breather issues spitting it out the vent
    slopshop that had to change another set of crappy ripped Napa CV axles must've overfilled it??
    TACOTU3[QUOTED] likes this.
  2. Jul 26, 2024 at 3:50 AM
    Black97v6MT
    iMA0
    tacoLand USA
    do you use one of those magnetic plugs in the engine oil pan?
    i am searching for one that is compatible with the 5VZFE
    1997tacomav6[QUOTED] likes this.
  3. Jul 26, 2024 at 2:37 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Love Amsoil!
  4. Jul 26, 2024 at 4:04 PM
    hessian42
    hessian42 Well-Known Member
    Max
    DON'T USE GL5 in the TRANSFER case or TRANS. Both have synchros which will wear out prematurely if you use ANYTHING other then GL4 fluid. AMZOIL is GL5 and NOT good for the above, only the diffs.....
  5. Jul 26, 2024 at 6:15 PM
    1997tacomav6
    Denver
    No, I would like to find one for each with a magnet but with the Lexus bolt head. I have the Lexus bolt heads now
    Black97v6MT[QUOTED] likes this.
  6. Jul 26, 2024 at 6:17 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
  7. Jul 26, 2024 at 6:20 PM
    Black97v6MT
    iMA0
    tacoLand USA
  8. Jul 26, 2024 at 6:22 PM
    ChargedSHOTaco
  9. Jul 26, 2024 at 8:33 PM
    CA-Taco
    CA-Taco Well-Known Member
    Santa Cruz Mountainss
    1999 PreRunner TRD
    1999 PreRunner TRD 5VZ 3.4 V6 AutoTrans 4x4 Swap ADS Coilovers w/adjusters New OEM Bushing UCA and LCA @210k Mi Stock LCA, SPC UCA REH5108 Coilbucket Gussets Total Chaos Spindle Gusset DuroBump Front Bump Stop Alcan Springs +800 lbs +2" ADS w/adjusters Rear Shocks U-Bolt Flip-Durobump DuroBump 4.25” Bump Stops Custom Shock Relocation 4.88 Yukon Gears Eaton Front Locker SCS Ray10 16x8 Bronze 255/85R16 Cooper Discoverer S/T Maxx Dakota Digital SGI-100BT Speedometer Interface Stock Front Bumper with Custom Hidden Winch Warn M8 w/Synthetic Rope w/Factor55 Flatlink E Nguyen Works Bumper w/Dual Swing Outs (Greasable KP Off-road LCA Bolts for Swing Out Bearings) BAMF Sliders 4x Innovations Front and Transmission Skid Plates Dometic CFX 55im Fridge/Freezer Big 4 wiring Mod Singer 128.5MM Denso hairpin style (6 phase) 180 A (200 A Max, 150 A Idle) X2Power AGM Group 35 Battery Renogy Deep Cycle AGM 12 Volt 100Ah Battery Renogy 20A DC to DC Battery Charger Victron Energy SmartShunt 500 amp Battery Monitor BlueSea Bus Bar on Custom Engine Bay Mount Victron Energy SmartSolar MPPT 20 amp Solar Charge Controller Renogy 100 Watt Eclipse Foldable Solar Panel Osram Super Bright 100/90w 2900 lumen H4s Headlight Services Harness 13WL Brake Calipers Braided Steel Brake Lines OBDLink MX+ OBD2 Bluetooth Scanner & OBD Fusion App Kenwood DMX958XR Soundproofed Cab - Dynamat and Second Skin Wet Okole Seat Covers Rebuilt Engine when Head Gasket Failed (215k Mi) Hayden 699 Transmission Cooler (Replaced B&M 70264 Cooler) Magnetic Inline Transmission/Power Steering Filter 4 x 4 Conversion w/Yota1 Rebuilt AT, ECGS Rebuilt Front Diff, '99 Taco TC, Manual Hubs GFC Camper V2 LSPV Delete Funky Home Made Mud Flaps and Hangars (1/4” Conveyor Belt Material; 12” x 18”)
    The ‘00 owner’s manual specifies gl-4 or gl-5 for both mt and tc, and gl-5 for differentials. Did they change their specifications later?
  10. Jul 26, 2024 at 9:32 PM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Can login to toyota.com/owners and download the owner's manual for each vehicle based on the VIN.
    IIRC diff capacity is variable on whether it is 2WD or 4WD, engine type, wheelbase, and with or without locker.
    Looks like for my '04:
    FRONT DIFFERENTIAL
    Oil capacity, L (qt., Imp. qt.): 1.15 (1.2, 1.0)
    Oil Type: Hypoid Gear Oil API GL−5
    Recommended oil viscosity: SAE 75W−90
    REAR DIFFERENTIAL
    Extra long wheel base with rear differential lock system: 2.95 (3.1, 2.6)
    Above -18* (0° F) SAE 90
    Below -18* (0° F) SAE 80W or 80W-90
    TRANSFER
    Oil capacity, L (qt., Imp. qt.): 1.0 (1.1, 0.9)
    Oil type: Gear Oil API GL−4 or GL−5
    FWIW
    Walmart Supertech 80W-90 1 gallon $18.44
    Autozone STP 75W-90 1 quart $9.99
    Wulf likes this.
  11. Jul 29, 2024 at 6:07 AM
    smyles1632
    smyles1632 Well-Known Member
    2003 Tacoma
    Huh? GL-5 is listed in the manual for both transfer case and manual transmission.
    Factory manual.
    Directly from Toyota.
    CA-Taco likes this.
  12. Jul 29, 2024 at 6:15 AM
    Black97v6MT
    iMA0
    tacoLand USA
  13. Jul 29, 2024 at 7:58 PM
    Toyota Dude
    Where you perfectly level left to right? Could there be some in the axle tubes?
    Wulf and Black97v6MT[QUOTED] like this.
  14. Jul 30, 2024 at 5:33 AM
    Black97v6MT
    iMA0
    tacoLand USA
    that is entirely a possibility
    driveway has a small slope to drain. it depends whether i am nose in or backed in. water pools up on one side or the other then drains from the box
  15. Jul 30, 2024 at 9:25 AM
    #35
    Wulf
    Wulf no brain just damage
    rock raisin
    2qt is about right if you're not on a perfectly level surface. run it
    Madjik_Man likes this.
  16. Jul 31, 2024 at 3:48 PM
    #36
    hessian42
    Max
  17. Jul 31, 2024 at 8:44 PM
    #37
    smyles1632
    2003 Tacoma
    well, if a guy on youtube says so, it must be true...
    Madjik_Man and CA-Taco like this.
  18. Aug 3, 2024 at 10:20 PM
    #38
    Toyota Dude
    Edited the original post to clarify L (qt., Imp. qt.)
