Rear TSB with lift question
Discussion in 'Suspension' started by tooth sleuth, May 29, 2011.
  1. May 29, 2011 at 7:10 AM
    tooth sleuth
    tooth sleuth [OP] Well-Known Member
    Ben
    Maine
    Pyrite mica trd offroad
    5100's (front 1.75) all around, rear leaf TSB. Bestop supertop, OEM bed mat. Pioneer 3200 HU, Pioneer GM 9500f amp, Eclipse SC6900 Front, Rear Eclipse 5 1/4, Marv box with Arc 10 sub. Dampened all doors and back wall with BXTII and ensolite, Supertop, blacked out emblems, 2011 grille, bedmat
    i'm thinking to get the toytec aal to go with the tsb and 4 billy 5100's.
    will this cause any functional issues? (driveline or stability?)
    should i set the front billy;s at 2.5inches with that set up?
    also, will i be able to fit 285's at some point with this?
  2. May 29, 2011 at 1:49 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    With just the rear tsb, you should set the billies to 1.75" up front if you want to be level. You will not be able to fit 285's with that setup though.
