Rear TSB with stock shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maju, Sep 23, 2010.
  1. Sep 23, 2010 at 5:11 PM
    maju
    maju [OP] Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    Got the TSB done a couple weeks ago, I did not upgrade the shocks going to leave the stock ones on untill they fail. Unless some one knows for sure that they will not hadle what the truck is rated at load wise.
    here are some after pics:
  2. Sep 23, 2010 at 5:23 PM
    ruskastud
    ruskastud Well-Known Member
    Lenexa, KS
    '10 Tacoma Double Cab 4x4 TRD Off-Road
    AVS Hood Shield & In Channel Ventvisors, Console Vault, Disable Seat Belt Chime, WeatherTech DigiFit Floor Liners, Lighted 4x4 Switch, Ultra-Gauge, Rear Spring TSB
    I got the leaf spring TSB done yesterday. I'm sticking with the stock front shocks too on my Off-Road. Sits a butt hair higher in the back, but I think it looks good.
  3. Sep 23, 2010 at 5:42 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    You have the Sport model w/ the blue/yellow blisteins stock correct? Those are a good shock unless you want another setup, some put 5100 series at all four corners or just ones up front to level it out.
    I didn't think Toyota was swapping out shocks anymore on the newer models. When I had mine done it was a non-trd & toyota put the blue/yellow blisteins. They aren't doing that anymore either per the TSB.
    I have hauled plenty of wet bulk mulch & compost in the bed with no issues.
  4. Sep 23, 2010 at 6:29 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Got the tsb and only upgraded the front shocks to the billy's @ .85 to level it out.
    left the rear shocks stock,
    hell the ass end is so light the stock shocks are probably over kill.
    have had no problems at all
  5. Sep 23, 2010 at 7:19 PM
    maju
    Davenport Fl
    Yes TRD has the stock blue and yellow blistens. I figured they were good enough. But with everyone on here putting 5100's on, I was confused as to if it was just to level, or some other reason.
    I belive the truck looks fine, I have only about 60 lbs in the bed when I took the pics in the orig post as I just got the truck back from having the TSB done. I have between 250 and 300 lbs back there now and thats about what it will normally have.
    Thanks
  6. Sep 23, 2010 at 7:33 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Are tsb's free?
  7. Sep 23, 2010 at 7:37 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Yes. Except you have to deal with the stealership.
  8. Sep 23, 2010 at 7:39 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Ah then I see a set of 5100's real soon lol. Thanks
  9. Sep 23, 2010 at 7:41 PM
    S.B.
    Sean
    San Diego
    15 Taco
    The TSB doesn't give you the 5100s. They would give you the TRD off road billies, which aren't 5100s.
  10. Sep 23, 2010 at 7:48 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    I know I was just saying to get 5100's and the (free) tsb to help level out the back
  11. Sep 23, 2010 at 9:27 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No, they're not FREE.
    The TSB is only FREE when you're still under the factory warrantee.
  12. Sep 24, 2010 at 3:15 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    I just put 4 5100s on after the tsb was done last year. I put the front at .85 which raised it an inch and looks exactly level. I did it for the looks but what I didn't expect was the dramatic improvement in ride quality. The TRD shocks rode awesome I thought and had many compliments from passengers on how well it rode. The new 5100s are even better. In fact it rides almost like my father-in-laws GX470.
  13. Sep 24, 2010 at 3:58 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    So if I Add A leaf on my 05 tacoma thats pretty much a rear TSB correct? or do i have the replace the whole leaf pack. I still have the stock 3 leaf in the rear.
  14. Sep 24, 2010 at 4:03 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Not always....
    If the problem you have (that the TSB fixes) is covered by warranty yes it is.
    If warranty has expired then no it is not.
  15. Sep 24, 2010 at 4:58 AM
    TRDsport253
    Fife, Wa
    Only if they went by mileage. 2005 with only 36k
  16. Sep 24, 2010 at 8:40 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Yeah I'm under warranty still, got 30k to go!
  17. Dec 17, 2010 at 12:10 PM
    Poffdaddy
    Poffdaddy Member
    Carlsbad, CA
    09 Tacoma 4x4 TRD Sport Long bed
    TSB, AAL, TRD Baja suspension kit, SnugTop Cab-hi shell, front tint
    Not sure whether to add 5100's or not. Planning on adding a camper shell and I don't want to end up nose high.
  18. Dec 17, 2010 at 12:17 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Just adding 5100's won't raise the front of your truck. They're adjustable, which is how people are using them for a lift. You can keep 'em at 0 and you'll be stock height in the front still.
  19. Dec 17, 2010 at 12:30 PM
    Poffdaddy
    Poffdaddy Member
    Carlsbad, CA
    I was thinking .85 to level and didn't know if 5100's at 0 were worth the $285 over stock TRD Bilsteins.... The truck measures 2" higher in the back but looks more level than that to me so I am not sure what to do yet
  20. Dec 17, 2010 at 12:59 PM
    Pugga
    Massachusetts
    I'll go to 5100's when my stock shocks go out. I don't know about spending the money just to swap them out to keep them at 0. A shell isn't really that heavy, only a couple hundred pounds. It shouldn't squat the truck much, especially if you've had the TSB completed, at least it didn't seem to do much to mine. FWIW, I've heard the 5100's help the ride pretty significantly, even set at 0.
