Rear U-joint squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by caribe makaira, Dec 14, 2012.
  1. Dec 14, 2012 at 6:52 PM
    caribe makaira
    caribe makaira [OP] Well-Known Member
    Caribbean, Puerto Rico
    Just an FYI, I've been hearing a noise which I thought was the spring pack and shackles. Like an old beat up truck everytime it stops at an intersection. But to my amazement it turned out to be the rear u-joint which had almost rusted stuck, as in no movement at all. Been doing too many flooded roads here in the past 5 months.
    Damn them ungreasable u-joints.:mad:
  2. Dec 14, 2012 at 6:54 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    They are grease able
  3. Dec 14, 2012 at 7:04 PM
    caribe makaira
    Not OEM ones...at least not on my Truck...sealed
  4. Dec 14, 2012 at 7:08 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Same thing here. Non greasable, replaced at 90k miles.
  5. Dec 14, 2012 at 7:09 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  6. Dec 14, 2012 at 7:42 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The 2012 prerunners have grease fittings.
  7. Dec 14, 2012 at 8:40 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    my 2010 has grease nips on all of the drive shaft yokes
  8. Dec 14, 2012 at 9:13 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    When you guys say you don't have them, are you just looking at the center for a grease fitting? The fittings are on the outside of 1 cap on every u-joint. I would be surprised if you didn't have fittings. I can see how they are missed if the shaft is in the right position with the fitting facing up.
  9. Dec 14, 2012 at 9:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I recall reading that only 4x4s have greaseable U-joints.
  10. Dec 14, 2012 at 10:13 PM
    caribe makaira
  11. Dec 14, 2012 at 10:40 PM
    seric007
    seric007 Well-Known Member
    really? interesting...
  12. Dec 15, 2012 at 5:28 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    According to rockauto the 4x4 and prerunner use the same size u-joint. They use a 1 1/16 cap size. When time comes I will just use the 4x4 u-joint on my pre-runner.
  13. Dec 15, 2012 at 1:38 PM
    Asgard
  14. Dec 15, 2012 at 1:41 PM
    Asgard
    Cause yours is a 4x4.
  15. Dec 15, 2012 at 3:10 PM
    caribe makaira
  16. Dec 15, 2012 at 4:15 PM
    KenLyns
    Belly of the Beast
    Only on the 2.7L PreRunners, according to the maintenance booklet. :notsure:
  17. Dec 15, 2012 at 5:16 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Mine does. They are NOT on the bearing caps however. They are in the center of the U Joint..
  18. Dec 15, 2012 at 5:27 PM
    themuffinman619
    themuffinman
    Your moms house
    This. Rotate the drive shaft till you see the grease fitting. 2wd have 3 zerks. 4wd has 5.
  19. Dec 15, 2012 at 5:42 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    replacing ujoints is easy luckily.
  20. Dec 16, 2012 at 6:23 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    Just fucking grease them. Then you don't have to replace them. Gawd!
