Rear Uneven After RearSpring TSB....
Discussion in 'Suspension' started by Fmsvandal, Feb 4, 2011.
  1. Feb 4, 2011 at 12:59 PM
    Fmsvandal
    Fmsvandal [OP] Well-Known Member
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Toytec Ultimate 3" Lift, Light Racing UCA's, N-Fab Steps, Black Headlight Mod, Satoshi Thin Lip Grille, Painted Hood Scoop, Debadged, Bakflip G2 Cover, Pop/Lock, Alpine HU, Kicker Door Speakers, RE Audio Subs, Arc Audio Amps
    ...So when performing the Rear Spring TSB, is there any reason to remove the rear shocks? After noticing the rear of the truck is higher on pass side than the driver side, i looked down at the shocks and noticed a difference between where the top of shock mounts. Seems to be a finger size gap on pass side while driver side is flush. The truck was even before having the TSB done.
    Is this normal? Btw, i do have the 3" OME Complete Setup if it makes any difference.
  2. Feb 4, 2011 at 1:01 PM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Not normal. Take it back. I had it done and they replaced the shocks too, but I have a 2.7L SR5.
    Was the truck sitting level when you took the pics?
  3. Feb 4, 2011 at 1:19 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    just checked mine they look like your second picture
  4. Feb 4, 2011 at 1:28 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Truck is sitting level. im curious if they take out the shocks to do the tsb being as with the lift, they come with a little rubber spacer and it seems to be missing from the driver side causing it to be lower.
    Just called toyota and im going down there now to have them look at it.
  5. Feb 4, 2011 at 1:41 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Check the torque. Seems like that nut is a little loose which could explain the uneveness.
  6. Feb 4, 2011 at 2:41 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    just went to toyota and they got me scheduled for monday. Def looks like the driver side is missing required rubber spacers that come with shocks. Tech must of forgotten to put them back in.
