Rear vibration issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthAl, Feb 10, 2022.
  1. Feb 10, 2022 at 5:05 PM
    SouthAl
    SouthAl [OP] Member
    I had the TRD lift installed on my 2022 TRD OR MT shortly after I took delivery. I began to notice a vibration in the rear after it was installed. I can see my bed shaking when this occurs. I’ve also noticed the shifter shaking while this is going on. Begins to show up around 50mph. Dealer claimed it was out of balance tires and stiffness from new shocks should be expected. Had the tires balanced per their suggestion and it did not solve the problem. Truck was returned to the dealer and I’m waiting to hear back. Still running factory duratracs. Has anyone experienced an issue similar to this? Thanks for any input
  2. Feb 10, 2022 at 5:14 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Hopefully they can figure out what the screwed up!
  3. Feb 10, 2022 at 5:32 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    If it were an out of balance wheel/tire you would have had the vibe before the lift.
    What is used to lift the rear? Spacer? How high?
    Vibes in the rear aft lift usually caused by driveline angle. I don't think the TRD lift adds that much hight though.
    Also "stiffness from new shocks"? What a line of BS that is!
  4. Feb 10, 2022 at 5:42 PM
    SouthAl
    SouthAl [OP] Member
    1” block in the rear. OEM TRD shocks replaced the factory bilsteins.
  5. Feb 10, 2022 at 5:46 PM
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    Yeah pretty hard to screw up there eh.
  6. Feb 10, 2022 at 5:56 PM
    SouthAl
    SouthAl [OP] Member
    You’d think. I overestimated the dealers ability to install a lift
    Fatback17[QUOTED] likes this.
