Rear Vibration Issues - Fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PackCon, Dec 19, 2018.
  1. Feb 17, 2019 at 8:45 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You got a bad wheel berring in the rear. A mechanics stethoscope will be able to tell which one is bad.
    It's not a bad job pulling the axles. I did both mine even tho only one was bad.
    suppra87 likes this.
  2. Feb 17, 2019 at 8:46 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    If you read his latest update the vibes move front the rear to front as he rotate the wheels so it must be a wheel or tire.
    winkel, tcjacado and koditten[QUOTED] like this.
  3. Feb 17, 2019 at 8:53 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    I think if the vibration has moved to the front with the tire rotations, you should replace the front tires or at least have them pull them off and inspect the inside. Maybe they're delaminating on the inside. They obviously have something wrong with them. Just a suggestion.
    PackCon[OP] likes this.
  4. Feb 17, 2019 at 8:54 AM
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I am going to have them check this.
    tcjacado likes this.
  5. Feb 17, 2019 at 8:54 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I hate to say this, but at this point I would take it to a dealer and see what they say. Not necessarily have them fix it, just see if they can figure it out...
  6. Feb 17, 2019 at 8:56 AM
    koditten
    Kirk
    Central Michigan
    Any chance you got someone that would swap wheels with you for a couple hours?
  7. Feb 17, 2019 at 8:58 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    If the vibration varies from front to rear, I'd think maybe a bad tire. You could have a separation somewhere that's hard to see unless the tires are taken of and inspected.
  8. Feb 17, 2019 at 9:01 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Gotta be a bad tire
  9. Feb 17, 2019 at 9:02 AM
    PackCon
    Connor
    They are telling me a U-joint needs replacing...
    I have developed a clunk when going from reverse to drive recently. This one might make sense.
  10. Feb 17, 2019 at 9:12 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Don’t have the same shops that keep spinning you in circles check it, just grab your jack and do it yourself
  11. Feb 17, 2019 at 9:14 AM
    fe650
    fe650 Well-Known Member
    Put the emergency brake on, place in neutral. Motor off and get underneath the vehicle. Move the driveshaft up and down and rotate. There should be no movement, if there is then you have either a bad u-joint or slip joint. More than likely u-joint.
    Also, if you rotated tires and the vibration moved from front to rear then you may have a radial belt broken or de-lamination. Only way to tell is take tire off and inspect unless you see a bulge on the outside, even if a small one. Tires with 50K miles are well used and easier to damage with normal driving.
  12. Feb 17, 2019 at 9:19 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Should the CB have any movement?
  13. Feb 17, 2019 at 9:21 AM
    PackCon
    Connor
    They just showed me the u-joint. There is play in it. Since I’ve been getting clunking... might be it.
    I still think a tire issue. I have 60k miles on the tires (only 2.5 years old). Might be worth taking the tires off to inspect.
  14. Feb 17, 2019 at 9:21 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Where do you feel the shaking in your seat? Or is the back Of the truck shaky?
  15. Feb 17, 2019 at 9:24 AM
    #35
    PackCon
    Connor
    The shaking in the rear is not in my seat, its back towrds the bed.
    My steering wheel vibes but the vibrations aren’t felt in my driveline like they don’t cause problems with steering. Like the vibrations are visible looking at the wheel but I don’t feel it in my hands.
    Shaking is only upon accelleration. It dissapears with decelleration. Over 55 mph its a hellish buzz that drives me nuts.
  16. Feb 17, 2019 at 9:30 AM
    #36
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
  17. Feb 17, 2019 at 9:32 AM
    #37
    casey2012
    mark
    yota
    none
    rear pinion bearing or tooth off ring gear drain your rear see if lots metal in gear oil
  18. Feb 17, 2019 at 9:36 AM
    #38
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    That's a drive line problem dude. Your tires and wheels don't stop spinning when you let off the accelerator, therefore... if it was your tires or wheels the vibes would remain. Replace your u-joints
  19. Feb 17, 2019 at 9:40 AM
    #39
    Trouble_The_Tacoma
    Conrad
    Badly balanced tires would be shaking in the steering wheel (bad balance up front) or in the seat (bad balance in rear).
    Good luck in fixing the problem. Have you curb checked anything pretty good? My brother has a double cab long bed and has a tendency to smack the rear tire on turns. He had some rear diff problems he had to get fixed.
  20. Feb 17, 2019 at 9:42 AM
    #40
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I know you keep saying that it is not drive line vibrations, but you don't feel drive line vibrations in the steering wheel. its an issue with your driveshaft angles/bad u-joint or bad slip joint causing the back of the truck to shake. if the vibrations were moving as they rotated the tires then when it shakes in the front, you would feel it in the steering wheel. if you have never felt any vibrations in the steering wheel then im betting it is driveline vibes and its something to do with your driveshaft. bad u-joints probably but could also be bad slip joint/carrier bearing.
