Rear Vibration Issues - Fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PackCon, Dec 19, 2018.
  1. Feb 17, 2019 at 7:45 PM
    #61
    KJP
    KJP Well-Known Member
    Kevin
    2013 Tacoma DCLB
    Elka coilovers, supercharged, 4.56 gears, ARB front and rear, 255/75/17 BFG, other stuff that weighs a lot
    Glad you got it fixed. I was reading the thread and about to jump in with "have your driveshaft balanced". I just came from a similar issue - a vibe at 40 that was driving me nuts. After lots of figuring had the driveshaft balanced and it turned out the front yoke had become unbalanced. How that happened is beyond me - only 50k on the truck and nothing changed in the last few months. None of the mechanics can figure out why it happened. I guess it is what it is - stuff happens.
    PackCon[OP] likes this.
  2. Feb 18, 2019 at 4:12 AM
    #62
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    $180.
    Not bad in my opinion.
  3. Feb 18, 2019 at 4:23 AM
    #63
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Glad you got it squared away...these things can drive you nuts.
    PackCon[QUOTED][OP] likes this.
  4. Feb 18, 2019 at 5:41 AM
    #64
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Could you add “Solved” to your thread title? Helps others out when searching for similar issues.
    Congrats on finding the fix!
    winkel and PackCon[QUOTED][OP] like this.
  5. Feb 18, 2019 at 5:44 AM
    #65
    PackCon
    Connor
    You got it.
    PzTank[QUOTED] likes this.
  6. Feb 18, 2019 at 7:54 AM
    #66
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Nah. Not to replace the warm and fuzzies of having a trouble free truck.
  7. Feb 22, 2022 at 1:00 PM
    #67
    tacoma909sport
    tacoma909sport Well-Known Member
    So Cal
    14 DoubleCab Sport
    can i ask to verify, they modified the balance of the shaft? it was not just as simple as replacing the u joint?
    i’m chasing the same problems, i haven’t gone to the depths of balancing the wheels over and over, but im at a point i want to go to a leaf spring company and have them go through my leaf pack. ever since my AAL, i’ve had issues. and now i’ve invested the labor of adding the 3° axle shim for the lift, and im still chasing the vibe.
  8. Feb 22, 2022 at 2:05 PM
    #68
    PackCon
    Connor
    They just replaced the U joint. No rebalancing that I’m aware off.
  9. Feb 22, 2022 at 3:08 PM
    #69
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    yeah ok cool thanks.
    im chasing what to i believe is a rear end shimey. not sure if it’s wheel balance of the 1.5” add a leaf, and then i tried to cure it with 3 u joints and a oem spicer carrier bearing. just before that i added a 2.5° shim and helped my operating angels. now im contemplating a bigger wedge axle shim like a 3 or 3.5°.. i need to measure my shafts again.
    then i wonder if the fact i’ve never had a wheel alignment ever would could play a factor..? i wish i knew some good toyota mechanics.
  10. Feb 23, 2022 at 3:26 AM
    #70
    PackCon
    Connor
    I don't know a whole heck of a lot about all the things.
    I will tell you if it's wheel alignment you should notice something in your steering wheel usually.
    But I will also say wheel balance and alignment isn't something bad to check. It's quick and easy and checks a couple boxes off.
    Are your leads in good condition? I no longer own my truck but one of my drivers side leafs was busted. As far as I know there was no symptoms created other than obviously the frigging sag they get under load but the stock leafs really blow. Especially if you live in an area that promotes rust.
  11. Feb 25, 2022 at 1:34 PM
    #71
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    i know you mentioned you sold the truck and this might be a while back now, but im going to ask what happen to your leaf spring? one cracked in half? what kind of symptoms did you have with your spring? happen to have pics? did you fix it?
    i recently did the add a leaf, and ever since then i want to say i’ve noticed vibrations at different speeds. i’ve measured my driveline angles and shimmed the carrier bearing, and i’ve also tried to repair the rear diff angle with axle shims. it’s better, but not oem specs, so still trying to dial down the real issue. super hard trying to find a vib only between 55-60mph. depending on the cb drop kit, the vib changes to 55-60mph. it’s starting to drive me crazy.
  12. Feb 25, 2022 at 1:48 PM
    #72
    PackCon
    Connor
    I noticed it was cracked at least on the outer portion (assuming through and through) I had sagging and squeeking but unsure of any other issues. None that were obvious to me. The squeeking wasn’t anything extreme or obnoxious.
    I did not fix it.
  13. Feb 25, 2022 at 2:33 PM
    #73
    tacoma909sport
    So Cal
    14 DoubleCab Sport
    got it. i’ll inspect again. but i really feel like im chasing my tail lately. i think im going to have to get an alignment to rule that out. im just hoping i don’t need a new set of tires. i just got some new toyo open AT’s, they are sweet. and i still only have like less than 5k on them.
    thanks for the tips.
  14. Feb 14, 2025 at 2:37 AM
    #74
    530kat
    530kat New Member
    2019 Tacoma sr5 limited 4x4
    3in lift
    I am having the exact same issue. Not a constant thing. Twice so far in approx 2mo time frame.
