Rear vibration upon acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by simontorres38, Apr 11, 2018.
  1. Apr 13, 2018 at 7:49 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    I’d remove those yesterday.
  2. Apr 13, 2018 at 9:55 PM
    badger
    badger Well-Known Member
    07 SR5
    That is trouble on a stock spring Simon. A small block for leveling purposes is reasonable, but using blocks as a lift kit is not a good idea.
  3. Apr 16, 2018 at 8:30 PM
    simontorres38
    simontorres38 [OP] Active Member
    Simon
    2012 Black Tacoma sr5
    Yeah I’m trying to get rid of them ASAP they are giving too many headaches
  4. Apr 17, 2018 at 8:49 AM
    b2948kevin
    b2948kevin Well-Known Member
    Kevin
    Highland, UT
    2010 Double Cab Long Bed 4x4 TRD Sport Black
    None yet
    Double check that the U-joints are intact also. I had very similar symptoms which progressed to the point where I couldn't ignore it over the course of about a month. I read tons of threads about the angle issue with drivelines, and was convinced that this was the issue until I finally climbed underneath and discovered that one of the U-Joints was completely destroyed. $200 later, a driveline shop had all the U-Joints replaced and I was back in business.
    Could be the balance issue, but just make sure that everything looks intact. It could be something obvious which was overlooked.
    simontorres38[OP] likes this.
