Rear View Activation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bwehman, Feb 3, 2016.
  1. Feb 3, 2016 at 6:27 PM
    bwehman
    bwehman [OP] New Member
    Bruce
    2016 Tacoma TRD
    Hi,
    Has anyone figured out how to activate the rear view when not in reverse on the 2016?
  2. Feb 3, 2016 at 6:30 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    If it's like other manufacturers, the radio looks for a reverse signal on the CAN data line. Can't just "turn it on"
  3. Feb 3, 2016 at 8:00 PM
    andyr562
    andyr562 Well-Known Member
    Andy
    Long Beach Ca
    Saw this post by @oops
  4. Feb 3, 2016 at 9:16 PM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Putting into reverse while driving ...
    andyr562 and Kentuckytaco2006 like this.
  5. Feb 3, 2016 at 9:16 PM
    DakotaTacoma
    DakotaTacoma Well-Known Member
    So. California
    1996, 2.7, 4x4, 5-speed, extra cab
    3" Downey lift, K and N FIPK, NWOR Try Y header, 31x10.5 BFG KOs
    You can probably just install a relay and switch. One side of the relay keeps it stock (power coming from reverse) and the other side supplies a constant 12v power to activate camera anytime. However, I have read that Entune may auto shut off the camera after 5-10 minutes, so it's not actually "full-time"
    A DPDT switch would also work and essentially do the same thing; except with a DPDT switch, there is an option for no camera.
    I plan on doing the relay version soon after I get my truck. Plus add a front canera using a DPDT switch.
    cactuscorn likes this.
  6. Feb 3, 2016 at 9:29 PM
    Bishop84
    Bishop84 Well-Known Member
    Send power to pin #2 on the large white connector, the wire colour is grey.
    -You can confirm this internet advice by measuring voltage to that wire when in reverse.
    This will send the reverse signal to the stereo.
    I may try this for trailing, it's risky as its much safer to ground a circuit as it is to power a circuit.
  7. Feb 3, 2016 at 10:50 PM
    Predator Strikeforce
    Predator Strikeforce TAC-TOY Build
    Utah
    '16 TRD ORDCLB QS
    Extreme Build in Progress!
    Used the reverse trick today while doing 80 down the interstate. Works as advertised...
    beertimecontinuum likes this.
  8. Feb 4, 2016 at 6:07 AM
    oops
    oops Member
    tri-state
    2019 4RUNNER TRD ON-ROAD
    It's something not a lot of folks are comfortable with haha. Putting your brand new vehicle in reverse while moving forward sends off a lot of warning signals! Just don't try to crawl and do it...
  9. Feb 4, 2016 at 6:50 AM
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    I'd be interested in tying it into a switch on the dash for on-demand rear camera.
  10. Feb 4, 2016 at 7:08 AM
    Mitchal
    Mitchal Well-Known Member
    Mitch
    2016 Tacoma
    I tried throwing it in reverse going 65 MPH on the highway yesterday.
    It did not work. I do not advise trying this. Luckily no one was seriously hurt.
    Who is the Jack-A$$ who recommended trying this?.
    .劉煒 and yesmar like this.
  11. Feb 4, 2016 at 7:26 AM
    bsacamano
    bsacamano Well-Known Member
    2016 Tacoma Sport DCLB V6 4x4
    I find it easier to put it into reverse while spinning a 180. That way, I can use the camera to see what's ahead of me and then just look directly at what's behind me.
    Kevindust likes this.
  12. Feb 4, 2016 at 4:57 PM
    bwehman
    Bruce
    2016 Tacoma TRD
    Thanks All,
    When I get up enough nerve (beer), I'll try the power to the grey wire.
