Rear view cam backwards??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDAY, Nov 12, 2009.
  1. Nov 12, 2009 at 8:05 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    Alright im confused this can't be how they are normally ok so theres a shovel on the left (drivers side of my truck) but on the cam it is on the right. Everthing is backwards i flipped it everyway possible when everything is upside down it shows so the shovel is on the right side but everything is upside down???
    What could this be???
  2. Nov 12, 2009 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats how it should be.
  3. Nov 12, 2009 at 8:09 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    Sober up a bit and look again?:rolleyes: LOL
    Have no clue bud. Hope you figure it out. I would like to install one myself.
  4. Nov 12, 2009 at 8:43 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    so its suppose to be a backwards mirror image so if theres a tree on ur left and u crank it to the right ur gonna nail it?
    I just cant get use to it i cant back anything up with it.
  5. Nov 12, 2009 at 9:38 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    Some rear view systems have a tiny switch setting for mirror or surveillance. I work on postal vehicles and there is a tiny switch that you flip with the tip of a pen on the back of the monitors which are installed in the trucks. Not sure what you're working with though.
  6. Nov 12, 2009 at 11:53 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    move the shovel to the other side. problem fixed. =)
  7. Nov 13, 2009 at 8:37 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    i have a kenwood 5120 HU
  8. Nov 13, 2009 at 8:43 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    If you turned your head around and looked out the back of the truck which side would the shovel be on? The right side. The camera displays the same image you would see if you turned your head around to back up. Makes sense to me.
    Now if the ground is on the top and the sky is on the bottom in your camera view I'd say you have a problem.
    Haha you're probably one of those people that thinks a bit too much and gets confused by the old double-sided DVDs that have wide-screen on one side and standard on the other. Do you put the wide-screen side down knowing thats how the disk is read? Or do you put the label side up thinking most people don't know how DVD players work? Its okay...I'm one of them too.
  9. Nov 13, 2009 at 9:57 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    alright say i put the shovel on the left side in my truck i turn my head around and look its on the left side but on the monitor it views it on the right side. Thats whats confusing me.
    nah im usually pretty good with this stuff because im a cable technician and im only 22yrs old so im not like my father who knows nothing about electronics or doesnt want to know lol
  10. Nov 13, 2009 at 10:09 AM
    SManZ
    Fauquier County, VA
    Ok...I think I get what you're saying but I want to be clear.
    You put your shovel on the DRIVER's side of the truck bed. You turn around and physically look at it and it is of course still on the DRIVER'S side of the truck bed.
    Your rearview camera shows that the shovel is on the PASSENGER side of the truck. Is this all correct? If you look at a sign through the rearview camera, are the letters reversed? They should be if what I described matches what you're getting out of your camera. In which case I have no idea whats the cause could be...
  11. Nov 13, 2009 at 10:12 AM
    Snowman20
    Snowman20 Active Member
    Cody
    Vancouver
    07 Trd Off-Road 4x4
    i am SO confused
  12. Nov 13, 2009 at 10:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The camera still shows it on the driver side, but the driver side is on the right when viewing the display.
  13. Nov 13, 2009 at 10:15 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    if you put your shovel on the left side of your truck, turn around, and it's still on the left, somethings wrong..
  14. Nov 13, 2009 at 10:17 AM
    SManZ
    Fauquier County, VA
    If thats what he's got then everything is fine since thats the exact same thing you see if you physically turned your head around to look out the back of the truck right?
    Major confusion here...if thats not what you're seeing RDAY I think some pics would be in order. And we want proof that your shovel doesn't have legs!
  15. Nov 13, 2009 at 10:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Me thinks somone is looking thru the cammera while stoned.
  16. Nov 13, 2009 at 10:21 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    :rolleyes: x2
  17. Nov 13, 2009 at 11:23 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yeap!:eek:
  18. Nov 13, 2009 at 11:55 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    you should take your truck back immediately..it has teleporting powers!! you do NOT want to be responsible for the outcome of this...:D
  19. Nov 13, 2009 at 11:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hes OK, as long as he doesnt walk Behind it. :eek:
  20. Nov 13, 2009 at 12:11 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    not sure which way your explaning it but on kenwood HU's they have an option in the headunit itself to reverse the image if you want to.
