Rear View Camera KIT.
Discussion in 'Buy / Sell / Trade' started by Pablotacoma, Aug 30, 2012.
  1. Aug 30, 2012 at 10:34 AM
    Pablotacoma
    Pablotacoma [OP] MD.Pablo
    Pablo
    Tj. Mex
    PreRunner
    Not yet, but I'm working to fix my tacoma
    SOLD.....
    My 1rst Post, I Have The Rear View Camera for Tacoma 2010, 11, 12. OEM New. all for $ 200 OBO.
    ThanK You.
  2. Sep 4, 2012 at 8:57 AM
    08navytrd
    08navytrd Well-Known Member
    Kenneth
    Italy
    08 Prerunner TRD Sport
    K&N CAI Flowmaster super 40 dual exhaust, Upgraded 6 disc from factory single disc, mag light attached to driver door, bilstein 5100 set at highest up front and 5100s in the rear, 1.5'' add a leaf in rear, aftermarket black headlights, 35w hids 6000k low beams, 4 85w HID off road lights 6000k color,
    quick question will this work in a 2008, and it doesnt look like enough wiring???? if this will work ill take it.
  3. Sep 4, 2012 at 10:24 AM
    Pablotacoma
    Pablo
    Tj. Mex
    PreRunner
    TACOMAS,
    from 2010 they adapted the cameras until 2012, for your 2008 be wanting to harness and know it adapt...
  4. Sep 4, 2012 at 10:36 AM
    08navytrd
    Kenneth
    Italy
    ok i didnt understand any of that.... sorry i must be reading it wrong.
  5. Sep 4, 2012 at 11:10 AM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Its a pain in the ass for 05-08 with no wires. The 09-12 have existing wires in the Tacoma to hook it up to. Even if you don't have that camera from the dealer.
    If you're a 05-08. You're better off going after market as running a wireharness and making it work will cost more in the end.
    Buy the OEM Handle with an option for back up camera and place a aftermarket inside. Then run it to a Head Unit. You win with a bigger screen in the end.
    Judging by the picture. The wire harness missing is the one from the Mirror to the Lower Dash. The the Lower Dash to the harness in the tailgate (PICTURED by OP). That alone believe it or not is $450 from the dealer! Wires I tell you. . .
    You're better off if you really want this to find the wires at a junk yard or have a guy fab one up. . . Then the time and effort will cost $$$ in the end.
    Aftermarket I tell you. .
  6. Sep 4, 2012 at 11:18 AM
    08navytrd
    Kenneth
    Italy
    duely noted thank you
  7. Sep 4, 2012 at 12:29 PM
    Pablotacoma
    Pablo
    Tj. Mex
    PreRunner
    Thank you for the Answer RAD....
  8. Sep 8, 2012 at 9:00 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    awe, its not that hard is it?! i used a gentex mirror w/ an oem camera with mine. i ran pwr/gnd/signal wire to the gentex mirror, ran one of those 5 in 1 wires (dont know the official name) from home depot from the camera directly to the mirror and i was off and rolling. took me less than 30 min to run all the wires adn hook it all up.
    now, using the OEM mirror might be different, but supposedly gentex makes the OEM mirror, which is why i went with it. i say if you have the camera wire harness plug and the mirror wire harness plug (or even if you could get one from gentex) i will be an easy mod!
  9. Sep 10, 2012 at 12:34 PM
    Pablotacoma
    Pablo
    Tj. Mex
    PreRunner
    ThanK You.[/QUOTE]
  10. Sep 11, 2012 at 7:35 AM
    earcandy4tim
    earcandy4tim Active Member
    Tim
    Hayden, ID.
    13 Tacoma Dbl Cab LB Sport
    Does this have the Homelink feature?
  11. Oct 2, 2012 at 8:21 PM
    rregueiro19
    rregueiro19 Member
    raul
  12. Oct 12, 2012 at 12:36 PM
    Pablotacoma
    Pablo
    Tj. Mex
    PreRunner
    SOLD......
