Rear View Mirror Keeps Falling Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jerimyr2000, Nov 15, 2016.
  1. Nov 15, 2016 at 12:37 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Trucks with outside mirrors don't need the inside mirror. Can't see much with it anyway if you have a canopy.
  2. Nov 15, 2016 at 12:44 PM
    Jerimyr2000
    Jerimyr2000 [OP] Well-Known Member
    Jerimy
    2015 PreRunner Texas Edition
    Well I will start with purchasing a new button and another pack of rear view mirror glue and go from there.
    For me it's a non issue, for backing up I have a camera that works fine for me.
    The wife always complains when I have a few too many beers and she ends up driving without a rear view mirror. I need to get the mirror back on so it doesnt affect my beer drinking!
    Pigpen and Mitch76 like this.
  3. Nov 15, 2016 at 12:52 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Wasnt sure where you were going with that last statement, but i like where it ended up!
  4. Nov 15, 2016 at 12:53 PM
    Lefthook
    Lefthook Well-Known Member
    New jersey
    2014 DCLB
    Tonneau cover
    I have always glued the button directly to glass. If the black area you are talking about is vinyl then I do not think it will stick. If it is a black porcelain area similar to the black area on some windshields interior outer perifieral for sun shading then it should stick.
  5. Nov 15, 2016 at 12:59 PM
    Lefthook
    New jersey
    2014 DCLB
    Tonneau cover
    I just went out and looked at my 2014. It has the porcelain area where the mirror gets glued to. If yours is soft maybe there is old glue that still needs to be removed. Be careful not to scratch it. Use a flat razor blade and carefully slice off the old glue and residue. Another point in following the directions on the kit would be to only prime the glass. Do not put primer on button and glass. Good luck.
  6. Nov 15, 2016 at 1:16 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    tomwil[QUOTED] likes this.
  7. Nov 15, 2016 at 4:33 PM
    Pigpen
    Dan
    Northwest Montana
    The best reason!
  8. Jul 10, 2020 at 8:18 PM
    steveb559
    steveb559 New Member
    2013 Toyota Tacoma
    Thanks, that’s what I was thinking but wanted to make sure. I appreciate it
