Rear view mirror not showing image from camera
Discussion in 'X-Runners' started by Bam527, Feb 25, 2013.
  1. Feb 25, 2013 at 7:08 PM
    Bam527
    Bam527 [OP] Member
    McCalla, AL
    2010 X-Runner
    URD short throw kit
    I bought my x runner feb 2011. It has the back up camera but the mirror has never shown an image. I was wondering if anyone else has had this problem and if it's an easy fix?
  2. Mar 1, 2013 at 3:45 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I would first check that the connections are good and check that your getting voltage at each of these points. Start at the mirror and work your way back. Check fuses just to make sure.
  3. Sep 9, 2013 at 2:43 PM
    t3hk
    t3hk Active Member
    10 PreRunner SR5
    Not being a troll...but I think there's a button you can press to turn it off on the mirror (I have a 2010 PR with the back up camera)...check that first.
  4. Sep 13, 2013 at 12:12 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    You should be able to press and hold the button at the bottom center of the mirror to access a menu...there is an "always off" setting in there if you look around a bit...
  5. Sep 13, 2013 at 12:15 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Any chance the tailgate camera cable connector was unplugged to remove the tailgate and never reconnected ?
  6. Sep 13, 2013 at 8:31 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I gotta ask...
    You know it only shows up if you're in Reverse, right?
  7. Sep 13, 2013 at 8:38 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I was running with out a tailgate for a couple weeks and with it unplugged a blue screen would show up on the mirror when I placed the truck in reverse.
    :rolleyes:
  8. Sep 18, 2013 at 2:37 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
  9. Sep 18, 2013 at 9:09 PM
    OZ-T
    Peter North
    British Columbia
    I did not know that
