rear view mirror wbackup camera wiring
Discussion in 'Audio & Video' started by Rlang1234, Oct 19, 2011.
  1. Oct 19, 2011 at 9:20 PM
    Rlang1234
    Rlang1234 [OP] New Member
    2011 PreRunner access cab
    Does any no the best way to hook up the stock back up camera to a new stereo (Kenwood DDX-418). I was thinking of splicing into the wires coming from mirror but dont know color code.
  2. Mar 5, 2012 at 9:51 PM
    tyrelri
    tyrelri New Member
    x2. i have this same question
  3. May 10, 2012 at 11:32 PM
    superman2481
    superman2481 Well-Known Member
    Bump this up!!! I've used the search button but still can't find anything, I had my buddy who's an installer try to wire up the '09 factory camera into my aftermarket double din and he's having issues finding the correct wore diagram, right now when I put the car in reverse it'll show on the screen" make sure to check behind" but won't show a picture! Any suggestions??
  4. May 10, 2012 at 11:36 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
  5. May 10, 2012 at 11:46 PM
    superman2481
    Thanks!! I'll show my buddy tomorrow
  6. Jun 25, 2012 at 9:36 PM
    mne3312
    mne3312 Well-Known Member
    Alabama
    '10 Prerunner SR5
    K&N Air Filter, Weather Tech Floor Mats, Weather Tech Deflectors, Truck Covers USA Roll Cover, 15% front 5% back Tint, Toyota Hitch Cover, Pop & Lock 8521, Pioneer 4400BH, Infinity 6-1/2" Speakers, 4-Channel Amplifier, Access Bed Mat
    well, did you guys get your cameras hooked up with this info.? I am looking to hook my oem back up camera to my new pioneer 4400. is this all of the info. I need?
  7. Jun 26, 2012 at 8:46 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
  8. Jun 27, 2012 at 6:10 AM
    mne3312
    Alabama
    '10 Prerunner SR5
    Thanks Lurkin!! While waiting on all the stereo parts/accessories to arrive I wired this in last night. This is the best write-up that I have seen on the back-up camera hook-up. Thanks again!
  9. Aug 16, 2014 at 6:10 PM
    adameade85
    adameade85 Member
    davenport iowa
    11 tacoma access
    I am looking for a camera that's going to fit the rear handle. Advice? I do not want to spend 400 or 600 on a factory camera
  10. Aug 18, 2014 at 7:23 AM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
  11. Sep 25, 2014 at 1:53 PM
    adameade85
    adameade85 Member
    davenport iowa
    11 tacoma access
    I purchased the Rostra backup camera that ties into the factory prewired kit. however, right now I took a light tester to the wiring and I am getting no power. I am trying to hook up to the JVC kw-v40bt. I am wondering if you know of a fuse that runs the camera wiring. like I mentioned before,. I can not get any power out of the wiring for the camera. I get the tester to light up with the reverse light red wire when engaged, so I know that isn't an issue. I also tested the factory wiring for the display mirror and no power there either... where is the power produced for this camera system? is there a certain fuse? any help would be appreciated
