rear wheel bearing advice please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buzzkill657, Dec 7, 2022.
  1. Dec 7, 2022 at 7:05 PM
    Buzzkill657
    Buzzkill657 [OP] Well-Known Member
    Jeff
    I have a 2012 with 69k on the clock.
    I have only owned it for 6 months and 4k miles. bought from Louisiana so history is unknown.
    I have a right rear wheel bearing bad and here comes the question.
    Should I go ahead and replace the left rear while its in the shop? They will cut me a deal on labor so its enticing. And if im going to do both rears I might as well put new rear brake shoes on and have drums machined since shoe replacement will have no labor cost as its part of doing the bearings
    All advice and opinions accepted.
    Thank you
  2. Dec 7, 2022 at 7:13 PM
    Longtech
    Longtech Well-Known Member
    Long
    SoCal
    15' OR converted 4WD
    I would just replace the bad side. Save some money.
    definitely have them replace the axle seal also.
    Kolter45 and HappyGilmore like this.
  3. Dec 7, 2022 at 7:16 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    No labor costs I would slap the other bearing in for sure…
    Goldwrench likes this.
  4. Dec 7, 2022 at 7:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My right one was bad on my Tundra (same system). I did the job myself.
    Brakes, rotors, pads and new bearings/seals both sides was $795.
    I had the local auto shop press off and on the new bearings.
    I did not want original equipment bearings (Toyota). I figured one went bad, why would I put the same ones in. Shop gave me a 5k warrenty if they failed. They have gone 150k with no issues.
    It's an easy job removing the axles.
  5. Dec 7, 2022 at 7:28 PM
    Buzzkill657
    Jeff
    no I may have mispoke. no labor charge for the brake shoe install. it would be 578 parts and labor for one side and 1066 parts and labor for both sides.
  6. Dec 7, 2022 at 7:30 PM
    Buzzkill657
    Jeff
    im looking at brg napa bearings with a 3 year warranty as the replacment parts and I get a substantial discount at napa through my work
  7. Dec 7, 2022 at 7:31 PM
    Bishop84
    Bishop84 Well-Known Member
    Big thing is doing the axle seals.
    Honestly it's probably fine, but if one is gone, the other is going to go soon.
    Do both, new seals, new fluid. Rear is good to go for another 10 years.
    ToyoTaco25 and Goldwrench like this.
  8. Dec 7, 2022 at 7:34 PM
    Buzzkill657
    Jeff
    that was kind of my thought process. too bad i just did the fluids but a minor cost
    I know how this goes. If I dont replace both it will go out two weeks later. If I do replace both then (without knowing) the other bearing would have gone to 200k
  9. Dec 7, 2022 at 7:36 PM
    Bishop84
    I just did one on a 2006 with 250k miles. (both axle seals blew, plugged breather)
    IT SUCKED. Everything seized, oil sprayed everywhere. Miserable.
    You are making the right choice.
  10. Dec 7, 2022 at 7:37 PM
    Buzzkill657
    Jeff
    That reminds me that i need to check my breather again
  11. Dec 7, 2022 at 8:14 PM
    koditten
    Kirk
    Central Michigan
    Why does the gear oil need changed? I never changed mine.
  12. Dec 7, 2022 at 8:47 PM
    Buzzkill657
    Jeff
    I dont think it gets a full change but some fluid loss is to be expected i read.
    koditten[QUOTED] likes this.
  13. Dec 7, 2022 at 8:49 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    I wouldn't worry about replacing the good side.
    I had an OEM fail on me last year. Replaced only that one side.
    20,000 miles later, I've had to replace the aftermarket one again, while the original OEM one is still good.
    Make sure the shop is installing quality bearings.
    Buzzkill657[OP] likes this.
  14. Dec 7, 2022 at 8:50 PM
    Buzzkill657
    Jeff
    im getting my own bearings from napa BRG bearings with a 3 year warranty
    HappyGilmore[QUOTED] likes this.
  15. Dec 7, 2022 at 8:51 PM
    HappyGilmore
    Huntsville, AL
    Yes
    Good news
  16. Dec 7, 2022 at 8:52 PM
    Buzzkill657
    Jeff
    and your vote is to only do the bad bearing?
  17. Dec 7, 2022 at 8:54 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Just replace both. They have both done about the same miles. Then when both of your non OEM bearings fail, you can replace them in tandem again.
  18. Dec 7, 2022 at 8:55 PM
    Buzzkill657
    Jeff
    are you not a fan of aftermarket bearings?
  19. Dec 7, 2022 at 8:58 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Correct- I am not a fan of aftermarket bearings (or parts in general, unless they proven to be better than OEM). These pieces cost a considerable amount to replace, mainly in time/labor that the cost the parts is fairly negligible. Ya gotta figure that replacing the bearings twice is less expensive than replacing them once.
    RockfishTaco likes this.
  20. Dec 7, 2022 at 9:01 PM
    Buzzkill657
    Jeff
    im just not too impressed with factory ones out at 69k miles. doesnt mean aftermarket are better. Just makes me a little apprehensive to buy toyota parts
