rear wheel bearing advice please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buzzkill657, Dec 7, 2022.
  1. Dec 9, 2022 at 6:15 AM
    #61
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    I feel like this has been covered but Just wanted to add my $.02 lol. my 2010 just rolled 300K with the original rear wheel bearings still going strong. I would only replace the bad one and I would use factory or equivalent.
    Buzzkill657[OP] likes this.
  2. Dec 9, 2022 at 6:25 AM
    #62
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm pretty sure these are pre greased, sealed bearings. A stopped vent will have had nothing to do with the bearing failing.
    If you see oil, then you know you have a failed seal that allowed gear oil to wash out the grease.
    I'm sure once you remove the brakes, you will see the bearing is bone dry and sounds like gravel.
    6 gearT444E likes this.
  3. Dec 9, 2022 at 7:50 AM
    #63
    Buzzkill657
    Buzzkill657 [OP] Well-Known Member
    Jeff
    no oil leaking out. Everything I can see is dry.
    I’m gonna get a koyo bearing and the seals and stuff from Toyota. Gonna do just the one side for now.
    thanks for everyone’s input
