Rear Wheel lockers engaged, slips to neutral.
Discussion in '1st Gen. Tacomas (1995-2004)' started by seancanterbury, Nov 3, 2008.
  1. Nov 3, 2008 at 9:19 PM
    seancanterbury
    seancanterbury [OP] Well-Known Member
    SLC, UT
    02 4X4
    When my lockers are on and im going up a hill often the truck will shift into neutral and the car will rev and ill start to go backwards. Anyone know why its automatically shifting into neutral? Starting to get annoying cause i have to restart my run at the hill...being a 2wd automatic :mad:
  2. Nov 3, 2008 at 9:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Since you have an automatic .... when you say it'll shift into neutral -do you mean the transmission shifter actually moves into neutral? Or does the shifter stay in drive when it occurs?
  3. Nov 3, 2008 at 9:46 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't see how the locker would affect the trans. Unless something is going on in the diff that is disengaging.
  4. Nov 3, 2008 at 9:48 PM
    seancanterbury
    SLC, UT
    02 4X4
    the whole shifter moves into neutral. ive tried to hold it back while giving it gas but it seems to really want to go. didnt want to hold it back too long and end up dead in the middle of the trail.
  5. Nov 3, 2008 at 9:50 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Damn that sounds real bad, Time to brain storm. What would cause your shifter to move, have you ever tried to wheel with the locker off and see if it would happen? Can you recreate this?
  6. Nov 3, 2008 at 9:52 PM
    seancanterbury
    SLC, UT
    02 4X4
    i thought for a while that it was just being rattled into neutral on the bumps, but then just going up dirt hills it did it. havent tried it without the lockers engaged yet. ill give that a shot tomorrow and see
  7. Nov 3, 2008 at 9:56 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I just can't seem to figure what would mover your shifter into neutral. Unless you were in some brush and got the linkage caught. Maybe if it does it see if you can put it in a lower gear to see what would happen.
