Rear wheel spin
Discussion in 'Wheels & Tires' started by Cdn98TacomaSR5, Aug 1, 2008.
  1. Aug 1, 2008 at 9:19 PM
    Cdn98TacomaSR5
    Cdn98TacomaSR5 [OP] Active Member
    Vancouver, BC
    1998 Tacoma SR5 Special Edition
    Nadda, except mags
    I've got a 98 Tacoma SR5 4x4 with BF Goodrich All Terrains. The engine is the 4 cylinder model with an automatic transmission. Even though the truck is underpowered I experience terrible wheel spin on the rears whenever the ashphalt is wet (which in Vancouver is almost all the time). On a flat surface the rear wheels will spin far too easily, even with gentle application of the gas. I have tried varying the air pressure between 30-50psi but it makes no difference. The previous owner installed beefed up rear springs and the truck has a bit of a nose down, rear up stance now. I'm not sure if this has anything to do with it. Has anyone else experienced this problem or know why this vehicle is spinning the rear wheels so easily and how to rectify this?
  2. Aug 1, 2008 at 9:23 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Have you tried lowering the pressure even lower than 30. Not sure about the 98 models, but check your door jamb for the recomended tire pressure. Also, you might think about adding some weight to the rear of your truck. Trucks have bad traction on the slippery stuff when they are unloaded.
  3. Aug 2, 2008 at 11:52 AM
    Cdn98TacomaSR5
    Vancouver, BC
    Nadda, except mags
  4. Aug 2, 2008 at 12:12 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Post a couple pics (of the truck and rear suspension). Are you sure he installed a new leaf pack or did he go with an AAL or block. What your describing sounds like axle wrap.
  5. Aug 2, 2008 at 1:34 PM
    Cdn98TacomaSR5
    Vancouver, BC
    Nadda, except mags
    This is the picture of my leaf springs.
  6. Aug 2, 2008 at 2:52 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    WHat is up with that over load?
  7. Aug 2, 2008 at 3:24 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I had the SAME prob with those damm tires- they hydroplane too much too! I got em off the truck and got me some Michelins. IMO it's the tires
  8. Aug 2, 2008 at 3:58 PM
    Cdn98TacomaSR5
    Vancouver, BC
    Nadda, except mags
    The guy that owned the truck before me over loaded the springs because he had a business that he needed to load the box with heavy materials for his business. He said they are 3/4 ton leafs.
  9. Jun 8, 2020 at 8:34 AM
    JFS
    JFS Member
    2003 2.4 Tacoma regular cab
    swapped bench for bucket seats, monstalinered the bed.
    Hmm, I have the same symptoms going on with my 2003 Tacoma. The rear is high and I bet the previous owner beefed up the back springs because it was a haulage company. Anyone know how this particular case resolved?
    Update: Turns out that my tire pressure was for max load psi (44) on all my tires and above max load for one. I dropped everything back to 36, and I've only slipped once since then, plus the ride is much better.
    Nice when the easy solution you try first works.
  10. Jun 9, 2020 at 12:55 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    I weighed my access cab
    less than 1700 pounnds on the rear
    For U the added rear leafs might have made it worse
    U might have less weight over Ur rear
    check with a good tyre tech That KNOWS the difference in compounds
    good luck
