rear wheel stuck on hub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fireman903, Oct 28, 2015.
  1. Oct 28, 2015 at 3:40 AM
    fireman903
    fireman903 [OP] Well-Known Member
    new jersey
    06 taco
    3 inch lift 33 in tires undercover emergency responder light 30 rigid led light bar bed lights engine compartment lights
    I'm trying to remove me rear wheels from my truck but I cant seem to get it off (yes all the lug nuts are off )
    I have tried penetrating oil and smacking it with a hammer but I don't want to damage the rims
    can any one shed some light on how to get it off
  2. Oct 28, 2015 at 3:48 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    You need to adjust the shoes in. There's a little star wheel in the drum behind a rubber oval plug in the back of the drum .
  3. Oct 28, 2015 at 3:49 AM
    fireman903
    new jersey
    06 taco
    the drum isn't the issue it getting the wheel off
  4. Oct 28, 2015 at 3:52 AM
    Gearheadesw
    Davenport Fl
    The shoes of the brakes are stuck in the drum. You need to get the brake shoes away from the drum to pull it off.
  5. Oct 28, 2015 at 3:53 AM
    Large
    Large Red
    He is saying his wheel is stuck to the drum ..
    Alexely999 likes this.
  6. Oct 28, 2015 at 3:54 AM
    Gearheadesw
    Davenport Fl
    Wait I'm sorry. Not trying to get the brake drum off. Actual wheel wont come off. Force will get you everywhere.
    Blockhead likes this.
  7. Oct 28, 2015 at 3:55 AM
    Gearheadesw
    Davenport Fl
    No reading comprehension. Sorry.
    Blockhead and Alexely999 like this.
  8. Oct 28, 2015 at 4:01 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I don't think the others are getting it.....The problem is NOT removing the brake drum. It's removing the wheel/tire from the lugs/hub.
    How long has it been since it was off? (Dis-simular metal corrosion??)
    Make certain you're supported well (with jack stands) before "attacking" the wheel. I'd start with putting a 2X4 or some solid piece of wood against the outside of the wheel and then giving that a firm smack with a HEAVY hammer. Next, if that doesn't break it loose, try the same thing only hitting the INSIDE edge of the rim. Use something (wood) to deaden the blow a little bit so you don't mark up the wheel.
    Next, you'll need some sort of wheel puller. Never saw one that wouldn't pop loose with a persuader....(ie BFH, aka Heavy hammer)
    Alexely999 and Dagosa like this.
  9. Oct 28, 2015 at 4:04 AM
    Gearheadesw
    Davenport Fl
    Yeah, I was fucking the whole thing up.
    Bluegrass Taco likes this.
  10. Oct 28, 2015 at 4:05 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    It's early.....
  11. Oct 28, 2015 at 4:21 AM
    Gearheadesw
    Davenport Fl
    Yeah, that's it.
    Hope OP gets it. I've never had a wheel not come off with a good kick or two.
  12. Oct 28, 2015 at 4:28 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I had one stuck on a '69 Chevy Nova I was restoring years ago. I took all the lug nuts off and beat on the rim for a while. I tried letting the jack down and driving it up and down the driveway to see if that would break it loose. No love.... So I gave up for the time being and walked down to the pond to go fishing (that fixes ANYTHING!) . My wife walked out to the shop to see if I wanted anything from the store. She saw the Nova sitting there, keys in the ignition, and jumped in it to drive to the store. When I walked back to the shop, the Nova was gone. This was before cell phones. I had no clue who took the car and where....
    An hour later, she drove back into the driveway, totally oblivious to what had just occured. She pulls up in front of the shop, stomps on the brakes.....and the wheel falls off.
    k8md likes this.
  13. Oct 28, 2015 at 4:31 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Yep...this is exactly what I always did...use wood and tap around the perimeter of the wheel. Been a while ?
  14. Oct 28, 2015 at 4:36 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    First time I pulled mine every one was a little stubborn. A few swift kicks to the tire freed them. Not a huge amount of force since I'm only a 135 lb guy.
  15. Oct 28, 2015 at 4:36 AM
    Gearheadesw
    Davenport Fl
    Ohhh, that could've ended bad.
  16. Oct 28, 2015 at 4:38 AM
    fireman903
    new jersey
    06 taco
    yea I have never seen this before usually a good shove or kick broke them free but for some reason this one is being a bitch I will try a bfh and a piece of wood
  17. Oct 28, 2015 at 4:41 AM
    Gearheadesw
    Davenport Fl
    Good luck, keep trying. Show it who's boss.
  18. Oct 28, 2015 at 4:41 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    The other thing I did which work also was to put the lugs back on finger tight, lower the car and drive back and forth while hitting the brakes hard to stop it. Emulate the story previously given. Nothing like making sure the pressure is up and hitting a bump or pot hole.
    Plain Jane Taco likes this.
  19. Oct 28, 2015 at 4:46 AM
    fireman903
    new jersey
    06 taco
    that wont damage the lugs?
  20. Oct 28, 2015 at 4:58 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    As long as they are snug but no more then finger tight. You can tell with a free wheel how much to tighten and still have a slight amount of play in the wheel. You're not driving 80 mph. Besides, I always kept the lug nuts on but loose even when I was tapping the wheel with a 2x4. Even on Jack stands I did not try to remove the wheel without lug nuts until it could be done freely...a safety thing. The forward / backward movement of the wheel on the hub with loose lugs will help break it off. If that fails. For me, it these things failed, it would be off to a garage with the safety of a lift.
