rear wheel stuck on hub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fireman903, Oct 28, 2015.
  1. Oct 28, 2015 at 6:09 AM
    Pigpen
    Dan
    Northwest Montana
    I used to work at a tire shop. When this occurred, we would hit the tire (not the rim) with a sledge hammer. hit it in different areas a couple times at each spot. Sometimes it took some whacking to get it off (your're welcome), but it always worked.
    Of course, the vehicle MUST be properly supported.
    DrFunker, Dagosa and landphil like this.
  2. Oct 28, 2015 at 6:36 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    This. 8lb sledge to the tire sidewall in various places to rock the wheel back and forth once it starts to budge, do it on the inner sidewall from underneath if really stubborn. Inflating the tire to max pressure helps some too, be careful of the hammer's rebound off the tire too.
  3. Oct 28, 2015 at 6:48 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    If you don't want to roll with the brute force method, get a decent heat gun, set it for Balls Out Flaming, and warm up the rim from the hub-side. You can use a torch if you prefer, but when mine were both stuck the B tank was empty (D'oh!).
    Before I had the heat gun, the same thing happened to the wife's Matrix. I boiled 6 gallons of water on my crab cooker and dumped it on the wheel, right onto the lugs, heard a 'pop' and the wheel came right off. Brute force has its place, don't get me wrong.
    Dagosa likes this.
  4. Oct 28, 2015 at 7:17 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Let's not confuse this issue with logic and science.......you're out of line. This IS a brute "force and ignorance crowd.":ballchain:
  5. Oct 28, 2015 at 7:23 AM
    opiestaco
    opiestaco Well-Known Member
    Wolcott, VT
    05 Tacoma SR5 V6 6speed 4X4
    Lifted with 285/75r16
    Hitting the tire from the back side works way better for me when I have this problem. But make sure the truck is well supported before doing it.
  6. Oct 28, 2015 at 7:34 AM
    obscurotron
    N. Nevada
    '14 DCSB 4x4
    I've found that when I use brute force, I end up succeeding in the original objective, and then breaking a bunch of other shit in the process. That's fine if you're an 11-Bravo, but not so fine if the wife is trying to get to work the next day. Talk about Hell's Fury!
    Alexely999 and Dagosa like this.
  7. Oct 28, 2015 at 8:16 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Good kick or two usually works, if not put the weight of the truck back on the tire.... just DO NOT let jack down so its not supporting any weight. As soon as the wheel breaks free its going to drop the weight back on the jack.
    As always. Parking break on and wheels chocked
    Dagosa likes this.
  8. Oct 28, 2015 at 9:50 AM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    I have had best luck with a sledge hammer and hitting the tire, not the rim. Scares the hell out of me to do that while it is on stands. I have also tried hitting a piece of wood put between the hammer and the rim but that is pretty much impossible to do while trying to stay out from under the car/truck. good luck.
  9. Oct 28, 2015 at 10:10 AM
    SethB
    SethB Well-Known Member
    TDY
    **SOLD** 2009 DCLB 4X4 Auto
    OME Suspension, SPC UCAs, ARB Bumper, Smittybilt Winch, Ext Brakelines, SOS Sliders, 4x Innovation Rear bumper
    This is what I do, works every time
  10. Oct 28, 2015 at 10:41 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    loosen lug nuts a half turn. push hard to rock the truck from side to side. itll come off easily. paint the top of the drum and or inside of rotors to make it easier next time !! i prefer grill paint.. its also a lot safer for your wheels and or your head if the hammer rebounds back at ya
    06Tacooo and Dagosa like this.
  11. Oct 28, 2015 at 2:08 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    If all else fails. Stick a jack with a large piece of wood between the inside of the two rear tires then let hydraulics do the work. Though I've never seen one stuck that bad.
    Dagosa likes this.
  12. Oct 28, 2015 at 2:32 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I took a truck into the tire shop years ago with a flat tire that I could not get off the hub. I tried for a few hours in the driveway before I filled the tire and the compressor and headed off to the tire shop. The shop took a few more hours to get it unstuck. The old guy at the counter couldn't believe how much work it took to get it off. I use anti-seize on the back of the rim and hub to prevent this now.
  13. Oct 28, 2015 at 2:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    The loose lug nuts, hitting the throttle then hitting the brakes while turning left and/or right has worked for me (it may take a few attempts)
  14. Oct 28, 2015 at 2:49 PM
    DrFunker
    DrFunker Well-Known Member
    This happened on my 1990 with alum. rims. My mech. smacked it really hard with a bfh a few times from the back. He did have it on a lift, totally supported. Once the brakes were done he put a thin coat of anti-seize on the rim and put them back on.
    They were a bitch to get off though.
  15. Oct 28, 2015 at 2:52 PM
    #35
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Foot on the brake and slam (Don't really slam just press it in a little) the gas pedal. Works every time. Not joking did it on my dads F-150 broke it free in like 1 little press.
  16. Oct 28, 2015 at 3:37 PM
    #36
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    bingo, peice of 2x4 and the jack that comes with the truck works like a charm. also get some anti-seize before putting the alloys back on
  17. Nov 14, 2018 at 9:29 PM
    #37
    WillSki
    WillSki New Member
    Will
    2011 Taco
    I usually rotate the tires at 8-10,000 kms. The last two times 1 wheel (Alum rim?) required many hits with a small sledge against a 2x4 placed in various spots on backside of rim/tire.
    I think I’ll paint the backside of the rims.
  18. Nov 14, 2018 at 9:44 PM
    #38
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I wonder if OP ever got his wheel off.
    jv_74 likes this.
  19. Nov 14, 2018 at 11:30 PM
    #39
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nope, He is still whacking it off with a BFH.
    jv_74 and Alexely999 like this.
  20. Nov 15, 2018 at 2:09 AM
    #40
    devkurf
    devkurf Member at Large
    midwest
    I'd try lowering the wheel on a 2x4 on the inner and outer lips of the tire with a couple of lugs on at 3 and 9 o'clock backed out a full turn. Most of the time a sledge will do the trick though.
