Rear wheel well liners and sticky mud.
Discussion in 'Off-Roading & Trails' started by Swamp Donkey, Sep 16, 2011.
  1. Sep 16, 2011 at 9:46 PM
    Swamp Donkey
    Swamp Donkey [OP] Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    Is there any solution for the rear wheel well liners? I bought a 2011 Tacoma and work in the oilfield up in northern Canada. Anyways, I work with a few guys who run Tacoma's. Most of them say they are great trucks, except after the beating they take from all the mud, the rear fender bracket breaks off causing the fender to flap in the breeze and all them loose their plastic wheel liners. Does anyone produce a better mousetrap for the wheel well liner? Thanks!
  2. Sep 16, 2011 at 9:52 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't have an answer for you but I know what you mean I have not broken my bracket but I have had the mud weigh the plastic down and rub on the tires.
    Seeing as it is the weekend if you don't get an answer just keep bumping this to the top by simply posting a reply stating "Bump" by doing this it will keep this topic readily viewable when people log on.
