Rear wheels bounce when first driving away.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Dec 16, 2022.
  1. Dec 16, 2022 at 7:37 AM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    so sometimes I have noticed (especially when coming out of a turn). That when I first accelerate from a complete stop, the rear of my truck will seem to violently shake. This doesnt always happen, but rather seems to happen more when starting off at a turn or something like that. If I take my foot of the gas it then goes away and I can continue to drive like normal and go on about my day.
    Like I said rarely happens. No, I don't try and drive like a racecar, just typically normal smooth acceleration from a stop. It only happens occasionally and only from a complete stop. I have a factory suspension, no lift, no tires outside of factory specs. I have factory rims.
    Any suggestions would be appreciated!
  2. Dec 16, 2022 at 7:45 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    What year? How many miles? Assuming it's not related to your driving style (and it doesn't sound like it is), then I would get the back of the truck up on jackstands and give everything the wiggle test with as much effort as you can. Re-torque your rear leafs, check your carrier bearing, and generally go over everything with a fine-tooth comb.
  3. Dec 16, 2022 at 7:45 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Carrier bearing shot?
  4. Dec 16, 2022 at 9:09 AM
    kidthatsirish
    216K miles...i replaced the carrier bearing 100k miles ago...
  5. Dec 16, 2022 at 9:17 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Pinion bearing? It under stress at that time in what your explaining. Is it leaking or how much play do you have in it? Just a thought, many more many more smarterrrrr guys around here. :)
  6. Dec 16, 2022 at 9:19 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Usually not the bearing that goes, it’s the bushing surrounding it. Tell us more about the rear of your truck.
    Does it have a lift? If so, what?
    Have you checked torque on all bolts? Ubolts and all other leaf spring related should be torqued to 85ft#’s.
    How old are your shocks? Mileage? Any leaks?
  7. Dec 16, 2022 at 9:21 AM
    tcjacado
    tcjacado Well-Known Member
    When was the last time the u joints serviced (greased) or replaced?
    WOODY2 likes this.
  8. Dec 16, 2022 at 9:25 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Shocks and/or Leaf Springs.
    WOODY2 likes this.
  9. Dec 16, 2022 at 9:37 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    That means you should check it again, you have about the same number of miles on the replacement as on the original. And of course check the u-joints. The recommendation to be on jack stands is appropriate for this check, so chock the front wheels well.
    If you have access to a GoPro or similar with a magnetic mount, or an old cellphone you're willing to strap to the frame to shoot a video, you should be able to catch the source of the vibes if they're coming from the bearing or u-joints. Someone posted a video of carrier bearing bouncing around several months back, it was decisive proof of the cause of his Taco's vibes.
  10. Dec 16, 2022 at 9:39 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I bet new shocks might help
  11. Dec 16, 2022 at 9:43 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I suspect carrier bearing. Get under the truck and check that, the u-joints, and the transmission mount.
    ToyoTaco25 likes this.
  12. Dec 16, 2022 at 10:08 AM
    ToyoTaco25
    North Carolina
    Doesn't matter how many miles ago you replaced it, get under there and wiggle it. If it wiggles, then it needs replacing again. 100k is about all I get outta mine. Would be a good time to do U-joints as well.
  13. Dec 16, 2022 at 10:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Would axle wrap do this i wonder?
    Clearwater Bill likes this.
  14. Dec 16, 2022 at 11:45 AM
    kidthatsirish
    the number of miles was just for reference to the earlier post. I know that miles dont always equate to "time to replace"...lot of other factors can influence drivetrain component wear (type of terrain, towing, etc.)
    ToyoTaco25[QUOTED] likes this.
  15. Dec 16, 2022 at 12:19 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    when you replaced the carrier bearing did you go OEM or Spicer? The big box store brands will shred within a few thousand miles. Climb under there and push up and down; side to side on the bearing and report back.
  16. Dec 16, 2022 at 1:32 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    How bout the rest? ^^^^^
  17. Dec 16, 2022 at 1:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm in the axle wrap pool with these 3 stooges. :rofl::rofl:
    There is a prize for the pool winners, right? :thumbsup:
  18. Dec 16, 2022 at 1:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes but it's bitcoin
  19. Dec 16, 2022 at 3:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    Well whoop te do. A plastic trophy from the Dollar store would be more meaningful to me. o_O
    Jimmyh and tcjacado like this.
  20. Dec 19, 2022 at 9:05 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Probably worth more too.
