rear wheels dragging causing terrible mpg?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mark06yoda, Jan 11, 2024.
  1. Jan 11, 2024 at 1:32 PM
    mark06yoda
    mark06yoda [OP] Well-Known Member
    marcus
    2006 Black Tacoma TRD Sport DCSB MT
    jacked truck up, spun each rear wheel they spin for about 1 or 2 seconds then stops feels like they are a little stuck how can i post a video here?
  2. Jan 11, 2024 at 1:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When the rear wheel spins, it does a lot.
    It spins a bunch of other things, 1-2 secs is about right.
    I mean, it should stop pretty quick with all the components drag.
    Axle, spider gear, ring gear, driveshaft…….
    A video would certainly help.
  3. Jan 11, 2024 at 1:39 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That sounds about normal. The diff gears are going to slow it down, they aren't supposed to spin freely. If you don't hear the rear shoes dragging, it is probably fine.
    Best way to post a video is to upload it to YouTube, copy the link and hit the icon that looks like film, and paste the link.
  4. Jan 11, 2024 at 1:47 PM
    mark06yoda
    marcus
    i’ll get you guys a video hang on i’ll link it
  5. Jan 11, 2024 at 1:48 PM
    mark06yoda
    marcus
    i’ll get a video one second
  6. Jan 11, 2024 at 1:50 PM
    mark06yoda
    marcus
    https://youtube.com/shorts/i7d0VLBm_nU?si=qPDeVm0b4eH7plvr
  7. Jan 11, 2024 at 1:51 PM
    mark06yoda
    marcus
  8. Jan 11, 2024 at 1:53 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    How bad is the gas mileage?
  9. Jan 11, 2024 at 1:55 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Looks normal to me. Winter gas and heavier tires may be affecting you some. But yeah, what kind of MPG loss are we talking?
  10. Jan 11, 2024 at 1:55 PM
    TnShooter
    Deogee
    STOCK
  11. Jan 11, 2024 at 1:56 PM
    mark06yoda
    marcus
    i get like 11mpg you can go see my other post aswell i need to check my o2 sensors because my exhaust is shot
  12. Jan 11, 2024 at 1:57 PM
    mark06yoda
    marcus
    okay thanks man
    TnShooter[QUOTED] likes this.
  13. Jan 11, 2024 at 1:58 PM
    mark06yoda
    marcus
    like 11 mpg im guessing from my o2 sensor then because my exhaust has like 6 leaks, no muffler and was throwing a code but it’s gone now
    im waiting to get my obd scanner from Amazon so i can check the air fuel ratios
  14. Jan 11, 2024 at 2:00 PM
    TnShooter
    Deogee
    STOCK
    If you have an exhaust leak, the A/F sensor could being seeing a lean condition.
    In return, it will pour fuel to the engine to "compensate".
    But all that is speculation until we get the actual codes.
    No matter what, any leak before the converters, needs to be fixed.
    Torspd likes this.
  15. Jan 11, 2024 at 2:03 PM
    mark06yoda
    marcus
    i think there’s a leak after both air fuel o2 sensors, like the piece that joins the upper cats to the pipes after the cats in between there
  16. Jan 11, 2024 at 2:06 PM
    mark06yoda
    marcus
    there’s no leaks above the 2 cats coming down from the engine
  17. Jan 11, 2024 at 2:06 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yeah, I just read through your other thread. Your brakes aren't dragging. I'd focus on the exhaust leaks.
    Torspd likes this.
  18. Jan 11, 2024 at 2:10 PM
    TacoTuesday1
    SD CA
    If you have doubts about rear hub operation, inspect the rear brakes.
    generic ODB scanners do not provide data.
    If your AFR was off, you'd have a CEL.
    You have an exhaust leak. The O2 sensors detect this as lean. The ECM compensates by dumping more fuel. Causing worse MPG, among other things.
    There is nothing to check. The lifespan of an automotive wear part is 10 years. Your sensors are older than that. Not including an exhaust leak.
  19. Jan 11, 2024 at 2:12 PM
    mark06yoda
    marcus
    thanks man, you think changing the sensors would fix it or just fix the leaks??
  20. Jan 11, 2024 at 2:12 PM
    mark06yoda
    marcus
    okay thank you brother
