Rear wheels lock up when i make sharp turns in H4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A51TACO, Oct 21, 2010.
  1. Oct 21, 2010 at 9:56 PM
    A51TACO
    A51TACO [OP] Member
    Preston
    Colorado Springs, CO
    06 Double Cab Tacoma SR5 V6 TRD sport
    I went to the toyota dealership to have them fix my balancing issue that has turned into more than a balancing issue and now the "Big Guy" from toyota has to come down and take a look at it because the technicians can't figure it out, but anyways i remembered that i was having issues with the back tires locking up and skidding when i have the truck in H4, so i had the technician get in the truck and i showed him the problem, of course he had no idea what was causing the problem, (whats new?) so he went in and talked to his service manager. The manager comes out and says, that it is just a common thing that happens and it isnt an issue unless it happens when im going straight. (Ya no shit, thank you dumbass) The only problem i have with his excuse is that it is destroying my back tires (which the tech verified when he told my that my rear tires looked more worn than my front and he wasnt sure why) and considering i live in CO and i have my truck in H4 90% of the winter i need this fixed, any ideas or similar problems that any of you have experienced.
    I pre-searched and wasnt able to find any similar threads, please point me in the right direction if you know of any.
    Thanks ahead of time.
  2. Oct 21, 2010 at 9:59 PM
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    I can't provide an answer of any sort... but a comment instead: this seems dangerous as well as destructive to your tread, a locked up rear end results in sliding... not good unless you are trying to drift.
    Perhaps tell this to the Stealership/Toyota; your life may be in danger.
    Alexely999 likes this.
  3. Oct 21, 2010 at 9:59 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    You have the 4WD on when on dry pavement? If so, dont, use it on a slippery surface or a surface where the wheels are not getting full traction. If you have traction in 2WD, no need to have it 4WD.
    A ring on one of the gears might be messed up. Good excuse to throw a new gear ratio in :)
  4. Oct 21, 2010 at 10:03 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    if you still have warranty I don't think that's an acceptable answer from them...
    it's a safety concern man!
  5. Oct 21, 2010 at 10:05 PM
    A51TACO
    A51TACO [OP] Member
    Preston
    It doesnt matter if it is dry or wet. I usually only have it on during wet pavement but it it still locks up and skids on the pavement.
  6. Oct 21, 2010 at 10:06 PM
    A51TACO
    A51TACO [OP] Member
    Preston
    Ya it is is still under warranty but they say that it is a "ghost issue" and there isnt anything they can do about it, thats why i need to find someone with the same issue.
  7. Oct 21, 2010 at 10:07 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Don't use 4x4 on the pavement.
    Snow is different.
    OldManTacoFeels likes this.
  8. Oct 21, 2010 at 10:12 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    sounds totally normal to me. I have heard from many 2nd gen owners, and experienced it myself. Sharp turns, like into the drive way in 4 hi makes the back tires chirp, skid. Tight turns are harder to do.
  9. Oct 21, 2010 at 10:12 PM
    m3zy6
    m3zy6 Well-Known Member
    Reno, NV
    '17 TRDSport AC 6spd 4x4
    That's what he is saying.
    You shouldn't need to use it in those conditions. And if the conditions aren't bad enough to need it, then they aren't bad enough to allow slip in your driveline and you are just adding unnecessary stress to expensive parts.
  10. Oct 22, 2010 at 4:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah It matters- 4WD is made for lower traction/slippery surfaces. If you use it on stickier surfaces (like dry pavement) it's going to lock up/bind the drive line.
    The safety concern is your understanding and use of 4WD...not your truck. Slow down, use more gradual turns, and only use 4x4 when you really need it- not 90% of the winter just because.
    Warranties aren't carte blanche for the dealer to work endlessly on a truck. This sounds entirely like a driver issue...Not a problem with the truck. Using 4x4 on dry pavement is just a bad idea.
    Shawner1974 and plurpimpin like this.
  11. Oct 22, 2010 at 4:22 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x1000^^^^^^^^^^^^^^^^^^^^
  12. Oct 22, 2010 at 4:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have a mechanical LSD.
    Are you saying...the REAR locks up? Does it lock up in both 2WD and 4WD? Or just 4WD.
    Because, if it has anything to do with the LSD - it will do the same thing in both 2WD and 4WD.
    If this only happens in 4WD - then it's because you're driving in 4WD on dry/high traction surfaces & making sharp turns. AVOID driving in 4WD in dry conditions and high traffic surfaces.
    IF YOU NEED TO DRIVE IN 4WD ON DRY OR HIGH TRAFFIC SURFACES - DO NOT MAKE SHARP TURNS!!!!! This causes extreme pressure on the CV joints & the driveline.
    Have you noticed the trucks starts bucking or won't move at all? That's your first clue that things are binding up. DO NOT FORCE IT.
  13. Oct 22, 2010 at 5:34 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    true, of course if your using it on dry pavement it's gona have trouble, and yes prob chirp the tires. I didn't think people used 4x4 on dry pavement :p
  14. Oct 22, 2010 at 5:46 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    are you using it on dry surface?
    Keep it up and something expensive is going to give
  15. Oct 22, 2010 at 10:52 PM
    OmegaMan
    OmegaMan Well-Known Member
    The Woodlands Tx
    2010 DC TRD Offroad
    Front window tint, Silver Star headlights and Fogs. Katzkin Leather Interior, Heated seats, UnderCover bed cover, JVC DVD HD radio + NAV
    I would read the owners manual.
  16. Oct 23, 2010 at 3:50 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Even wet pavement doesn't provide enough slip for 4x4 in sharp turns. It sounds like what you describe is normal, and you're using 4x4 where you obviously don't need it.
    AJKlug1 and Shawner1974 like this.
  17. Oct 23, 2010 at 4:40 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    ^^^What he said^^^
    It's a part-time 4x4 and lacks front/rear differential so it will bind in sharp turns when there's good traction. It is NOT a full-time AWD like momma's CRV.
    What's amazing is the dealer didn't educate him on the differences...either when he bought it or when he complained to service or both times. I bought mine used at a used-car mega store and THEY took the time to educate me even though I told them I knew the difference at the outset.
  18. Oct 23, 2010 at 4:44 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    It's been said a few times, so I am just repeating, but stop using 4x4 on pavement! All you are doing is stressing things out that are eventually going to break.
  19. Oct 23, 2010 at 4:57 AM
    Nick Sells
    Nick Sells Well-Known Member
    Elgin, South Carolina
    2016 TRD Off Road
    Bone Stock
    What's the difference between AWD and 4 wheel drive not being smart i just don't know I allways assumed it was the same it seems like you shpuld be able to drive in 4hi if you want too why would they make it so it would screw things up in any conditions.
  20. Oct 23, 2010 at 5:10 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    The condition you describe will even happen on occasion in snowy slippery conditions we have in the Northeast.
    Try to turn sharp (don't!) in a parking space during a snowstorm & will get same effect (binding). I have forgotten on occasion ;)
    I have experienced this in all the toyota trucks I have owned since 87 even a couple of 1GEN tundras.
    Many people have said it here just saying it can even happen in snow.
