Rear wheels locked, all warning lights came on on my dash board
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xXDeadfishXx, Dec 26, 2021.
  1. Dec 27, 2021 at 5:57 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    This happens alot with Tacoma's. The brake cable is siezed up. You'll need new ebrake cable(s) to remedy the issue.
  2. Dec 27, 2021 at 7:37 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    You said in your post you normally use your e-brake on every park: That's good practice: It will help keep the cable from seizing up within the sheathing from prolonged non-use.... (That's likely not your problem: Truck is too new.) Except: when you have been driving in frozen slop, snow, just got a car wash or in rain when it's near freezing and certain to drop well below freezing overnight. Then you face two problems: shoes stuck to the drum, or in older trucks: cable stuck somewhere because water has intruded into the cable sheath. Might even be rotors stuck to the pads. The first: you may be able to move/rock it and break the shoe away from the drum: I would try reverse in 4L first, as others have advised and then 4H and then rock in 2H,4H and 4L. Be prepared for an impressive "clunk" or bang when it lets go: like you backed into a rock. If none of this works, a tow truck may be able to pull back a little in neutral to see if that works. Just make sure he takes it easy: you don't want to break cold things in there (drums). If that fails, see if you can get it towed to a heated garage. You should be on your way in a hour. (about the same time a frozen fuel line takes to thaw: been there.) I live in the northeast. I apply my e-brake everytime I park except if it has been snowing, frozen rain storm or sloppy roads covered in wet snow. If I hear a blowing snow storm is coming I leave the ebrake off too: even if I havn't or am not going to be driving it.
    xXDeadfishXx[OP] likes this.
  3. Dec 28, 2021 at 12:20 AM
    WestCoastMango
    WestCoastMango Well-Known Member
    Anthony
    Vancouver Island
    2019 DCSB
    Sounds like your rear brakes are frozen. Didn't read comments so I'm not sure what was suggested, but jack the vehicle up and remove the tires and hit the brakes with a mallet.
  4. Dec 28, 2021 at 3:42 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Planned to head up the mountain post Xmas. Weather thought otherwise.
    Came back home instead after seeing the conditions…
    OP - I hope all is ok now! update?
  5. Dec 28, 2021 at 6:48 PM
    xXDeadfishXx
    xXDeadfishXx [OP] Member
    Ashley
    2019 Tacoma Off Road
    BDS Suspension 6inch lift 33s with 18inch wheel
    Hey all,
    Thank you all for the response, I finally got it towed to a local Toyota dealer in Tahoe(Jim Bagan Toyota)
    Got my truck defrosted, and everything works fine, back to normal. They are super nice and reasonably priced.
    Lesson learned: don’t ever put your E break on in the cold weather, especially when you have a six inch lift, it increases the tension on the break cable.
    Thank you all for helping, travel safe
  6. Dec 28, 2021 at 6:50 PM
    xXDeadfishXx
    Ashley
    I tried, but it didn’t work. But you are spot on.
  7. Dec 28, 2021 at 6:51 PM
    xXDeadfishXx
    Ashley
    Yup. Thank you
  8. Dec 28, 2021 at 6:55 PM
    xXDeadfishXx
    Ashley
    Thanks brah, I tried all that, I had five folks tried to rock my truck and make it work, but I think I was just really out of luck that night. Tips from the dealer, don’t ever put my E break on in the cold weather.
  9. Dec 28, 2021 at 6:57 PM
    xXDeadfishXx
    Ashley
    I did that, didn’t work. =(
  10. Dec 28, 2021 at 6:58 PM
    xXDeadfishXx
    Ashley
    I’ll remember that brah, that’s a good idea!
  11. Dec 28, 2021 at 6:59 PM
    xXDeadfishXx
    Ashley
    Yes, it’s a taco issue
  12. Dec 28, 2021 at 7:00 PM
    xXDeadfishXx
    Ashley
  13. Dec 28, 2021 at 7:02 PM
    xXDeadfishXx
    Ashley
    Yeah, but there are so many good fellas around, they all help and gave me a ride to the hotel. I was safe and sound ^^
    gsubioguy and Canadian Caber like this.
  14. Dec 28, 2021 at 7:05 PM
    xXDeadfishXx
    Ashley
    Yeah, just got my truck back. Road Condition is still pretty bad if you are planning on coming up this way. But there’s so much pow, I’m happy that I got stuck here!
    gsubioguy likes this.
  15. Dec 28, 2021 at 7:06 PM
    #35
    xXDeadfishXx
    Ashley
    E break frozen
  16. Dec 28, 2021 at 7:08 PM
    #36
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Good to hear you're all good, OP!! Were you stuck there all this time? Weather was gnar. Were you able to hit the slopes while stranded?
  17. Dec 28, 2021 at 7:23 PM
    #37
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    I'm glad OP got a fix to the problem with minimal hassle.
