Rear Window - DIY ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Apr 28, 2012.
  1. Apr 28, 2012 at 7:50 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Hello, hello!
    During a massive paintball war, my back window in my 07 Tacoma had a fateful interaction with someone's head. The glass is broken. The dealership wants 800+ for the window; online I can find it for 300 shipped. My curiosity is, what DIY ideas are there for the rear window, excluding making it open automatically? Has anyone tackled the rear window in a project yet?
    -Will
  2. Apr 28, 2012 at 11:24 PM
    JKD
    JKD Well-Known Member
    Like, just DIY installation of a factory window? It's installed with a rubber gasket (like windshields were in about '65) so the installation method is probably similar. Personally I'd look into having a glass repair shop do the work. And if they supply the part, it will probably be warrantied (along with the installation). Since glass work can leak, a warranty would be a nice thing to have...plus if they break the glass during installation, it's on them and not you.
  3. Apr 29, 2012 at 12:13 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    Rear window install is easy peasy.
    Install the gasket on the glass.
    Place a thin rope (1/8" clothesline) in the bottom of the groove around the outside and the ends of the rope hanging out the top.
    Lift the window into place, getting as much of the body into the gasket as possible.
    While pressing the window against the body, a friend carefully pulls the rope, which "walks" the gasket onto the outside of the body the same way a tire machine works a tire onto a rim.
  4. Apr 29, 2012 at 6:28 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Spot on method ... great write up ... ;)
  5. Apr 29, 2012 at 6:49 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I too would look at havingit installed as said just for the warrenty. But in my case I would look into a solid window,I just don't use a sliding window.
    My .02.
  6. Apr 29, 2012 at 6:50 AM
    sicc83
    sicc83 Active Member
    The 2nd gen Tacoma back glass is bonded, not a gasket. It's not a DIY job, just take it to a glass shop.
  7. Apr 29, 2012 at 6:57 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    there is a thread on hear for auto opening rear window
  8. Apr 29, 2012 at 6:58 AM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    I have done a few when i used to do auto glass lets just say take it to a glass shop its glued and bolted
  9. May 1, 2012 at 2:19 AM
    kkasaki
    kkasaki Member
    which site did you find it for 300 shipped ?
  10. May 1, 2012 at 4:34 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    if your experienced enough it doesn't look that bad; otherwise a shop will prob do it on the cheap...was less than $100 for me...super simple install the guy said.
