Rear Window Motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by allents6, Sep 13, 2010.
  1. Sep 13, 2010 at 10:17 AM
    allents6
    allents6 [OP] Active Member
    TAllen
    Sweet Home Alabama
    06 Tacoma Double Cab SRS TRD 4x4
    K&N FIlter
    My right rear window motor has bitten the dust. Is there any chance it could be a switch rather than motor? It got where it would quit working and then work and then not work and now it is dead. If it is the motor how much trouble are they to replace? Of course when it finally did go the window had gotten rolled all the way down. So I have gotten it disconnected and held in place w/ some coat hangers...lol. Doesn't look like a lot of room in the door to do much manuvering.
  2. Sep 13, 2010 at 11:03 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denver
    '09 4X4 TRD Off-Road
    Lifted and bigger tires
    could be a switch, mine went out, it was a siimple fix, not sure how much though as mine was only 8 months old. if you can take to door panel off you could test the motor with a battery, and if it works then the switch is the problem, if not, go to a junk yard and buy a motor that works
