Rear windshield blew out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrandpoohbah, Apr 20, 2024.
  1. Apr 20, 2024 at 12:40 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Didn't even think this was possible. Was out doing some light off roading yesterday and hit a bump a bit harder than I expected. I heard a loud popping sound but didn't really think anything of it until I took the next turn and heard the sound of glass tinkling behind me. Turns out I blew out the passenger side rear windshield. The middle and driver side are both fine. Any idea how this might have happened? It doesn't look like the canopy could have made contact.
    Picture taken post clean-up, didn't think to get one while I was out on the trail.
  2. Apr 20, 2024 at 12:43 PM
    eon_blue
    Azusa, CA
    The cab may have made contact with the shell, that's my guess
  3. Apr 20, 2024 at 12:45 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is what is known in the off-road community as “ EORT “……… excessive off road torque
    Jimmyh and Steves104x4 like this.
  4. Apr 20, 2024 at 12:45 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Could be, especially since he just created another thread about breaking the front mounting point on the shell.
    TheWildMan and Steves104x4 like this.
  5. Apr 20, 2024 at 12:50 PM
    thegrandpoohbah
    Terrace, BC, Canada
    I though about that but the canopy is still pretty secure and can't be moved forward at all.
  6. Apr 20, 2024 at 12:52 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Your trucks frame flexed enough to either let the cap to hit the rear window. Or enough flex could have broken the glass. even if you hadn't had a cap.
    SH10151 likes this.
  7. Apr 20, 2024 at 1:00 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Crazy. Is there any other potential damage I should be worried about?
  8. Apr 20, 2024 at 1:06 PM
    MGMDesertTaco
    On my 3rd gen, the windshield will creak if it's super hot out and I take a corner at just the right speed with a dip in the street.
    I'd guess the shell hit the cab or the cab flexed too much when you were driving around.
    SH10151 likes this.
  9. Apr 20, 2024 at 1:08 PM
    50Buck
    To be fair, you can't possibly replicate what the trail does by hand. You can't move it, but you can't make your frame flex the way a trail does either. Trying to compare it while static in a parking lot or driveway, or even just a different part of the trail doesn't do much.
    SH10151 likes this.
  10. Apr 20, 2024 at 1:21 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Fair enough.
  11. Apr 20, 2024 at 1:29 PM
    50Buck
    That said, I think the most likely thing would be glass got a bit of torsion applied, and then an impact or drop on the trail made the glass pop. That, or there was a flaw or weak point in the glass and just the torsion made it break.
  12. Apr 20, 2024 at 1:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Good time to remove both the cab and cap winders and make it a pass thru.
  13. Apr 20, 2024 at 1:42 PM
    thegrandpoohbah
    Terrace, BC, Canada
    LOL, it rains WAY too much here for that!
  14. Apr 20, 2024 at 1:45 PM
    50Buck
    Ideally the pass through would have an accordion style connection so it would be water tight.
    Steves104x4 likes this.
  15. Apr 20, 2024 at 1:45 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Put a rubber gasket between the two and you’re good. You’ll save about 30 lbs, too.
  16. Apr 20, 2024 at 5:24 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    Expensive repair.
  17. Apr 20, 2024 at 5:34 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    If you replace the whole window please pull the center sliding window and gasket out. I will buy
  18. Apr 20, 2024 at 8:14 PM
    thegrandpoohbah
    Terrace, BC, Canada
    $300 insurance deductible.
