Rear wiring harness repair or replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco_Nooga, Jul 1, 2019.
  1. Jul 1, 2019 at 5:42 AM
    Taco_Nooga
    Taco_Nooga [OP] Member
    Chattanooga, Tennessee
    2004 PreRunner
    Working on it!
    So I've noticed the previous owner of my truck had U-Haul install a trailer harness by splicing into the vehicle harness (using tap connectors) just above where the spare tire hangs.
    The splices have deteriorated and need to be replaced.
    I would like to replace this portion of the vehicle harness rather than try to repair the splices. Is there a disconnect somewhere near the back or would I have to replace the entire harness starting at the engine and working my way back to the tail lights?
  2. Jul 1, 2019 at 6:49 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if you want to replace this section, you will have to replace the whole thing, from the cab to the tailights. Better to just replace the damaged/corroded wires, unless the wiring harness itself is damaged in multiple areas
  3. Jul 1, 2019 at 8:10 AM
    Taco_Nooga
    2004 PreRunner
    Working on it!
    Thanks, I thought that would be the case.
    Probably not worth the effort but I'm curious what the harness would cost. If anybody knows the part number of the harness please chime in.
  4. Jul 2, 2019 at 10:56 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    PM me your VIN and I can look it up for you
  5. Jul 2, 2019 at 11:05 AM
    Russianman92
    Dunwoody GA
    Without VIN assuming you have a V6 Auto here is the harness:
    Toyota Part No.: 82164-04641
    Around $400
    https://www.toyotapartsdeal.com/oem...(1=5VZFE;5=ATM;6=4FC;8=XTR;0=VZN195L-CRPDKAB)
    If you give me VIN I can confirm
  6. Jul 2, 2019 at 2:01 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I think you can do a fine job fixing that problem much cheaper
    Was that number in stock ??
  7. Jul 10, 2019 at 6:41 AM
    Taco_Nooga
    2004 PreRunner
    Working on it!
    My apologies, I got busy and haven't been on here in 10 days. @Russianman92 you are correct- I saw a label on the harness with that part number (82164-04641). @Wyoming09 I agree, will be much cheaper to repair though they do still stock it.
    Thanks guys!
