Rear Wiring Harness
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fox-15, May 16, 2020.
  1. May 16, 2020 at 9:18 PM
    fox-15
    fox-15 [OP] New Member
    DILLON
    2009 Prerunner
    The dealership said that I need a whole rear wiring harness, I cannot find the part anywhere or where to look for it on the truck tbh. They said it was corroded pretty bad but im thinking I should at least just try to clean it up before I pay someone to fix it or buy a new one, all help is greatly appreciated.
  2. May 17, 2020 at 3:56 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Why and what triggered the dealer visit?
    There is a separate towing harness for $100 but not sure on all the tails light wiring or license plate.
    Tow harness connector plugs in above rear bumper up under the bed towards the left side. It feeds the 7 pin trailer plug.
  3. May 17, 2020 at 11:25 AM
    fox-15
    DILLON
    2009 Prerunner
    The tail lights are working intermentintly, as in all of them, reverse, running, brake, and lisence plate. Usually half of them work at any given time
  4. May 17, 2020 at 11:42 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    For all of them to go bad the problem sounds it has a central cause. Try cleaning up your grounds. You can clean oily stuff out with contact cleaner.
  5. May 18, 2020 at 11:10 AM
    fox-15
    DILLON
    2009 Prerunner
    I checked the one ground i could find but the only problem is that I cannot find a good wirng diagram anywhere, not even in the repair manual i bought. It shows what connects to what but never says where.
