Rear won't level after AAL and 5100's
Discussion in 'Suspension' started by Taco's for All, Aug 15, 2010.
  1. Aug 15, 2010 at 10:28 AM
    Taco's for All
    Taco's for All [OP] Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    I got lazy and had my local shop put my AAL's in as well as my rear 5100's. Since then, I've begin to notice that the passenger side and drivers side will not level out with each other. Currently, I have a full tank of gas, and the driver's side is sitting just about 1.5 inches higher than the passenger side. It appears that they put the AAL's in properly as the long end is to the rear. I also had the rear TSB done about a year ago.
    Anyone have any insight on this?
  2. Aug 15, 2010 at 10:45 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the drivers side is taller then the passenger side? In the front or rear?
  3. Aug 15, 2010 at 10:46 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    That is the "taco lean" try adding a top plate spacer in the front on the driver side.
  4. Aug 15, 2010 at 10:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    1.5" diff from left to right?? Something isnt right. Can you take a pic of the front 5100's, near the lower spring seat?
  5. Aug 15, 2010 at 11:16 AM
    Taco's for All
    Lake George, NY
    My mistake. The REAR is what I can't get to level out. I double checked my measurements, and it's just more than an inch off. The front is fine.
  6. Aug 15, 2010 at 4:50 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    If the drivers side is 1.5" higher WITH a full tank of gas then something is way off; the "Taco-lean" is when the drivers front is lower than the rest of the truck.
    Is there any chance that you accidentally put a ".5" leveling spacer" on the passenger side front instead of driver's front?
    Might sound silly but are you parked on completely level ground?
  7. Aug 15, 2010 at 9:40 PM
    Taco's for All
    Lake George, NY
    The front is only off by .25" and will be fixed with the spacer that I have.
    My problem is with the rear end. Do the rear 5100's have to be put on specific sides? I am 99% positive that both shocks were the same length.
  8. Aug 15, 2010 at 11:11 PM
    nvdeserted
    Reno, NV
    The rear shocks shouldn't be side specific. Unless one of the shocks is like 5" too long it wouldn't change how the truck sits; shocks bear no weight, they just dampen the bounciness of the leafsprings, which determine 100% of the rear height. Your truck wouldn't raise or drop 1mm if you took the shocks off completely.
    Maybe one of the shackles is binded and not letting the leafspring sit properly.
    Maybe you were accidentally sent 2 different AALs, 1 at 1" and 1 at 2" lift or something.
    Are both of your front tires and both rear tires at the same PSI?
    Are there the same number of leafs in each pack?
    Are both packs mounted clean on the axle leaf-perch?
    Maybe go find a good rut or rock and flex the rear out completely on both sides a few times, it might settle.
