Rearend question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chan t, Oct 3, 2021.
  1. Oct 3, 2021 at 5:14 PM
    Chan t
    Chan t [OP] New Member
    08 Tacoma prerunner
    Will a door code of ao4c rearend out of a 05 work in a 08 with door tag of ao4b
  2. Oct 5, 2021 at 6:37 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    This should work. Code C is for LSD and in 05-08 it was a mechanical lsd so it is friction based. BUT this means you will lose your Elocker.
    Details on axle codes below copied from another post by Jeff Lange
    As the 2016 Tacoma is still the same frames/type as the 2005 to 2016, the axle codes go on from there.
    A = 8.0"/205mm
    B = 8.8"/225mm
    01 = 3.583:1
    02 = 4.100:1
    03 = 3.153:1
    04 = 3.727:1
    05 = 3.307:1
    06 = 4.300:1
    07 = 3.909:1
    A = Open
    B = E-Locker
    C = Limited Slip Differential
