Rearend squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Adamnlexy, Jul 23, 2016.
  1. Jul 23, 2016 at 8:41 AM
    Adamnlexy
    Adamnlexy [OP] New Member
    Adam
    07 Tacoma Prerunner xtracab SR5
    3" lift, 35x12.50x17 tires,
    I just Bought my first Tacoma. While driving at low speeds and as I accelerate there is a squeak that comes from the rear of the truck. Any suggestions on where to start for checking things would be greatly appreciated
  2. Jul 23, 2016 at 8:42 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    ujoints and center bearing
  3. Jul 23, 2016 at 8:42 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Leaf springs. Check to see if you have the TSB 3+1 pack installed of you don't then you know the problem. Even if you do they have been known to squeak too there are multiple forum posts on how to resolve the issue
  4. Jul 23, 2016 at 8:44 AM
    wilcam47
    Will
    Bourbon state
    if its U-joints you could try to grease them but more than likely if they are squeaking they are already worn and need replacing
  5. Jul 23, 2016 at 5:45 PM
    Adamnlexy
    Adam
    Thanks I appreciate the info. I already planned to replace the ujoints and bearing. Has anyone changed the bushing on the leaf springs I was looking at putting polyurethane in to see if that would help
  6. Jul 23, 2016 at 8:08 PM
    Pigpen
    Dan
    Northwest Montana
    I would just pull the bolts and cover them with anti seize. It's a good idea even if that's not what's squeaking.
    I put the headstrong poly bushings in with my Dakars. Seems like good quality.
