rearend topping out
Discussion in 'Suspension' started by wolfman00, Jul 21, 2011.
  1. Jul 21, 2011 at 12:40 PM
    wolfman00
    wolfman00 [OP] Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    I have a 2011 reg cab 4x4, with 2.25 spacer in front and 1" blocks in the rear. The rear now when I hit a bump feels like its topping out. I was told I could get away with using stock shocks with 1" of rear lift, but it sure rides like shit.
    I need a temp fix. I saw on toytec they have stud extenders. Would those work for a few months until I get the bilsteins?
  2. Jul 21, 2011 at 12:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Block lift + OEM shocks = poor ride, and topping out of the socks. You need shocks designed for more lift.
  3. Jul 21, 2011 at 7:15 PM
    wolfman00
    matt
    '16 dclb
    thats what I was thinking. toytec said the bilsteins are slightly longer? what would you suggest?
  4. Jul 21, 2011 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Get the 5100's in the appropriate size.
  5. Jul 22, 2011 at 5:21 AM
    wolfman00
    matt
    '16 dclb
    ok, thanks for the help
  6. Jul 24, 2011 at 8:54 AM
    wolfman00
    matt
    '16 dclb
    ok, so i decided to order OME's all around and 884s. ( did alot of searching so I got 90% of my answers)
    with the ome and 884s, what do you think my final height will be up front? I really want to stay around 2" I am not going to do any top plate spacers.
    the rear- think my 1" block will be fine with the ome or should i get a 1.5"?
    remember, its going on a reg cab, thats why i got questions. most everything i found was for ex. cab or dbl cabs, except for especks, and he used 885s.
    thanks in advance
  7. Jul 24, 2011 at 8:56 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You'll probably get 2 - 2 1/2" from the 884's
