Rearend whine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Iamraiderpower, Dec 25, 2015.
  1. Dec 25, 2015 at 5:54 PM
    Iamraiderpower
    Iamraiderpower [OP] Well-Known Member
    so I did some searching but didn't find any 12+ folks complaining of whine. Figured these trucks have few quirks and l hope this is one and not the pinion gear about to snap.
    2015 5k miles Peerunner stock tire/no lift. It isn't driven hard really all highway miles.
    Never really drive with music down but did today and noticed a loud rear end whine at 55-60ish mph when decelerating.
    Just seeing if anyone has any ideas before I call dealer on Monday.
    *UPDATE*
    Went to dealer yesterday, Turns out the rear end is failing, and will be replaced next week. When they tear it down i will post pics and info of why it failed
    New update 3/22
    Carrier bearing took a dump causing extra load on differential that caused edges of gears to wear down which caused my whine is what they said. So now I have a new differential at only 8k miles :yes:
  2. Dec 26, 2015 at 1:13 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Under warranty...let the dealer mess with it.
    Justus likes this.
  3. Dec 26, 2015 at 1:21 AM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Yep
  4. Dec 26, 2015 at 2:54 AM
    Greyyota
    Greyyota Member
    Ben
    Florida
    2014 tacoma
    5100
    I have the same problem .. Dealer said they couldn't hear anything had truck for 2 days let me know what you find ? Thanks
  5. Dec 26, 2015 at 3:02 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Likely driveline noise rather than pinion gear, based on the fact that it's on deceleration.
    Tacomas are really fairly noisy trucks. You can drive yourself absolutely ape-shit-crazy trying to diagnose every little sound. Interaction with a dealer over "my truck makes a noise" is likely to waste your time and have an unsatisfying result anyway.
    And Tacomas have a long powertrain warranty. In the unlikely event it turns out there's a differential problem, it'll still be warranted.
    My advice: don't sweat it and enjoy your truck.
    Ruggybuggy likes this.
  6. Dec 26, 2015 at 6:48 AM
    Jcollins
    Jcollins Well-Known Member
    Justin
    Browns summit north carolina
    2013 grey tacoma trd
    Light bar and pods with strobe back up camera any time mod 886 backup lights and a Detroit true track posi
    Whining on decelaration normally means you need different shims to correct backlash. Back lash should be .005 to .007
    Kyle01 likes this.
  7. Dec 26, 2015 at 6:49 AM
    Jcollins
    Justin
    I just replaced the rear end in my 2013 trd sport and getting the Shims right is what made my new rear really quiet
  8. Dec 26, 2015 at 7:43 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It is rare that a rear diff is quiet when slowing down in gear. As stated you have a 60K mile warranty. No worries.
  9. Dec 26, 2015 at 9:37 AM
    Iamraiderpower
    I'm not worried one bit, as I am a seasoned mechanic myself, but like bjmoose said they are noisy and I was just curious if this was one of those quirks about these trucks. This is my first taco, and I'm still learning their funny little bits about em. Thanks for the input folks :D
  10. Dec 26, 2015 at 9:49 AM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Mine has done the exact same thing since it was new. Glad to hear I'm not alone. 44k miles and a rear diff fluid change have passed and it still does it, no better and no worse. I'm assuming this is a non-issue and haven't had it checked out.
  11. Jan 23, 2016 at 2:15 PM
    11Taco2.7
    11Taco2.7 Active Member
    The rear diff on my 2011 2.7 started whining after a few days of mudding around (getting pulled out by other tacomas). I drove it from the Bay Area to Los Angeles after that and the noise. Just drive it and it will break in more.
  12. Jan 23, 2016 at 2:16 PM
    Iamraiderpower
    Yea ive got 7k on it now, and like others said (I kind of figured as much) it is just one of the funny things about these trucks
  13. Mar 16, 2016 at 7:14 AM
    Iamraiderpower
    posted update
  14. Mar 16, 2016 at 7:21 AM
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    Crazy it failed with hardly any miles. My truck gets rallied pretty damn hard with 33" MT tires and it's hanging in there good. Are the 4x4 and pre-runner different rear ends?
  15. Mar 16, 2016 at 8:32 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pinon bearings.
    Moms 4 runner had the same whine on decel from the rear end... due to bad pinion bearings from oil that had never been changed at 120k miles.
    Needless to say there is a reason why i changed the gear oil in my rear diff at all of 6k miles to get the nasty break in oil out.
  16. Mar 16, 2016 at 8:34 AM
    Iamraiderpower
    my guess is the Pinion also, but the tech said he thinks it might be worse o_O
  17. Mar 16, 2016 at 8:34 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I'm guessing your rear was low on fluid from the dealer. Or you got some lemon bearings/gears that failed.
  18. Mar 16, 2016 at 8:47 AM
    Iamraiderpower
    come tuesday we will find out lol ill be hanging out there with him taking as many pics as i can to document the findings
  19. Mar 22, 2016 at 12:28 PM
    Iamraiderpower
  20. Mar 22, 2016 at 1:30 PM
    vtdog
    vtdog Well-Known Member
    NH
    I used to hear a rear end whine when former girlfriend complained that her ass was too big (it was). So now both are gone
