rearview camera help
Discussion in 'Audio & Video' started by FlawedXJ, Dec 20, 2008.
  1. Dec 20, 2008 at 2:20 PM
    FlawedXJ
    FlawedXJ [OP] mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    Anybody have rearview cameras in their tacomas. I got a quick question
    I have a boyo license plate mount camera that plugs into my Eclipse AVN5510 by the yellow composite jack. The camera box says it will automatically come on when I put it in reverse, but it doesn't. Any body know how to make it do this? I have the headunit hooked up to the reverse wire so thats not the problem.
  2. Dec 20, 2008 at 2:36 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    is there a camera setting on the headunit itself? my pioneer has to have the camera function turned on the HU in order to see it, that way it doesnt come on to a blank screen whenever u throw it in reverse and there's no camera hooked up
  3. Dec 20, 2008 at 9:58 PM
    FlawedXJ
    Paul
    NorAla
    i've messed with those settings and the only way I can get it to work is if i select it as a video source.
  4. Dec 21, 2008 at 8:48 AM
    The_Hodge
    SC
    and do u have it hooked up to an AV input or a designated camera input?
  5. Dec 21, 2008 at 10:14 AM
    FlawedXJ
    Paul
    NorAla
    av. The camera input needs a special plug.
  6. Dec 21, 2008 at 5:49 PM
    The_Hodge
    SC
    well there's ur issue....the camera input would auto pop on w/ the reverse kicking in, but a regular AV input is only gong to come on when u kick the HU into AV. u have to either get a plug that'll work on the camera input or cange it to AV each time out wanna see out the back. thats why there is a seperate input specifically for the camera
  7. Dec 21, 2008 at 6:13 PM
    FlawedXJ
    Paul
    NorAla
    I know that much. Just was hoping to call out to other eclipse owners. Kinda sucks that they would limit that feature to only their camera.
  8. Dec 21, 2008 at 7:28 PM
    The_Hodge
    SC
    yeah...my pioneer just takes a standard coaxial cable like the camera u bought. just something more for them to rape u for later
  9. Dec 21, 2008 at 7:40 PM
    FlawedXJ
    Paul
    NorAla
    The cameras have the same wires just different end plugs. Maybe I'll try to wire something fancy up.
  10. Dec 22, 2008 at 11:41 AM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    My Kenwood had a setting buried somewhere. So, even though the backup ligt was connected to the unit, you had to configure the unit to switch the display to the backup camera when you back up.
    These units tend to have a zillion settings and I eventually found the right one.
  11. Dec 22, 2008 at 11:49 AM
    FlawedXJ
    Paul
    NorAla
    i had to order a special adapter for it to work the way i want it to. was 30 bucks online but found it for 10 from some random place out of indiana.
    btw, i know this is the only way cause i called eclipse.
