rearview mirror bracket bond to windshield failed..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chaosbound, Mar 20, 2014.
  1. Mar 20, 2014 at 4:18 PM
    chaosbound
    chaosbound [OP] Member
    Seattle, WA
    Ex Cab V6 4x4 SR5
    Does anyone out there have experience with repairing the "glue" that bonds the rearview mirror bracket to the windshield? The glue on my 2013 failed today and I'm not sure how to repair it.
    This windshield is a replacement after the OE cracked in a snowstorm. I've got the I'mMrYo mirror relocate bracket installed as well. I don't want to point any blame at I'mMrYo or his very well designed bracket. I believe the failure is with the quality of the replacement windshield mirror glue. It's been several months since I installed the mirror relocate bracket, and today was the first warm sunny day since the install.
    So, what's the best product to fix it? Was it difficult to do?
  2. Mar 20, 2014 at 4:31 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I'd let the windshield replacement co. know that their glue on the bracket failed.... That's their problem, not yours, IMHO.
  3. Mar 20, 2014 at 4:36 PM
    chaosbound
    Seattle, WA
    Ex Cab V6 4x4 SR5
    I thought about taking it back to the repair shop, but my thought is that they aren't liable to honor the repair since the mirror has been altered.
  4. Mar 20, 2014 at 4:49 PM
    tacotacoburrito
    tacotacoburrito Well-Known Member
    They just need to glue it back on, or you can get the glue yourself. It's not hard, nor is it expensive.
  5. Mar 20, 2014 at 4:52 PM
    File IFR
    Central MA
    You and I both know the aftermarket mirror bracket did not cause the glue failure ( I have one too :)).
    To play it safe and keep them from making excuses, remove the new bracket and have them properly clean the stub and glue it on and mount just the mirror only. Then go home and add your bracket. You're not trying to pull a fast one on them, you're only eliminating the opportunity for them to say "the mirror is too heavy now" or "that's not OEM", blah blah.
    A word of caution... They NEED to mount the stub pretty much in the original spot, otherwise the I'mMrYo's bracket could be too close to the headliner. Yes, that problem has happened and was mentioned in the bracket thread.
    ... Or just do it yourself. :)
  6. Mar 20, 2014 at 5:01 PM
    chaosbound
    Seattle, WA
    Ex Cab V6 4x4 SR5
    I totally agree File, no way the sweet mirror relocate bracket was at fault - I'm going to do it myself, just need to figure out the best possible glue and method to make sure it never comes off again!
  7. Mar 20, 2014 at 5:06 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I've been witness to those glues you can buy at VatoZone or Pep Boys not working worth a shit. We have a large fleet that these windshield buttons mysteriously fail, probably from ham fisters adjusting them.
    The fleet guy has used different kits and they all suck, either that or he does.
    Take it back, I'm positive the windshield guys deal with putting these things on all the time.
  8. Mar 20, 2014 at 5:07 PM
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2025 4wd Tacoma SR5 DC
    I have used Marine Goop on many vehicle rear view mirrors to reattach them. Not one ever fell off again.
  9. Mar 20, 2014 at 5:20 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Permatex makes a mirror bracket glue too that I've used and have had good results with.
  10. Mar 20, 2014 at 6:14 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Yeah, what he said. Make sure to remove all the old glue from bracket and windshield. Been a while since I've done one, but let bracket cure at least the recommended time before attaching the mirror.
  11. Mar 20, 2014 at 7:08 PM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    If you still have some glue that marks the spot you might want to use a marker to mark the location on the outside before you clean the glue off the inside.
  12. Mar 21, 2014 at 2:16 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    Get off all the old glue and clean everything with rubbing alcohol. It's the surface that you're gluing to more than what brand mirror adhesive you use that determines if the bond will last.
  13. Mar 21, 2014 at 2:33 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    and make sure you don't touch it with your fingers
  14. Mar 21, 2014 at 8:18 PM
    chaosbound
    Seattle, WA
    Ex Cab V6 4x4 SR5
    well, that was pretty easy! I probably went overboard on masking my dashboard, but I did NOT want a glue disaster on my dash. I used the Permatex kit and was careful to clean everything properly. Still glad I asked ya'll for advice though, because I had no idea about Permatex or Marine Goop.
  15. Mar 22, 2014 at 3:53 AM
    boopie
    boopie 05trdoffroad
    Ramon
    San Diego
    05trdoffroad
    Toytec/Eibach Bilstein set at .85, URD TCAI , TRD catback exhaust,1.5" AAL
    I just used gorilla glue. It's still holding after 2 years
