Rearview mirror
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkthompson6, Jan 13, 2011.
  1. Jan 13, 2011 at 8:45 PM
    bkthompson6
    bkthompson6 [OP] Well-Known Member
    Brandon
    Oregon
    I searched this and have only found complaints about it and no solutions. I am only 6' 1" tall, thats not too extremely tall, and it seems like the rearview mirror is right in my way at all times, right in the middle of the windshield it seems. That is the biggest blind spot in the truck. Is there a way to remove and relocate it? Or an aftermarket one I can place a little higher? Thanks for any suggestions.
    Brandon
  2. Jan 13, 2011 at 8:52 PM
    747 function > form
    1st Gen.
    Walmart has aftermarket mirrors...as far as removing the oem mirror, I'd go to a glass shop (assuming your oem mirror is mounted to the windshield). Once off, you shouldn't have any trouble mounting the aftermarket mirror yourself.
  3. Jan 13, 2011 at 8:54 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    flip it upside down and upwards, it'll lift it some. Not perfect but works for me at 5'10"
  4. Jan 13, 2011 at 9:46 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    This is what I do too. Works like a charm
