REASON FOR THE 2.7L...??
Discussion in '4 Cylinder' started by gray223, Jan 8, 2014.
  1. Jan 8, 2014 at 7:33 PM
    gray223
    gray223 [OP] Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Why even make the 2.7L when the v6 gets only 2 maybe 3 less mpg in town, but has 60+ more HP and torque. I just don't see much point I guess. Wondering what's everyone's opinion on this.
  2. Jan 8, 2014 at 7:36 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Different truck configurations. Not everybody needs/ wants a V6. Money and usage are factors.
  3. Jan 8, 2014 at 8:19 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I don't need 60+ more hp/torque and get way better than 2 or 3 mpg.
    Why the V6?
  4. Jan 8, 2014 at 10:22 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I always buy the cheapest base model truck with the fewest options, so I like the little 4 banger. :) Last fill up (town/freeway mix, winter blend) was 25.3 mpg. And my truck isn't all that slow either... ;)
    https://www.youtube.com/watch?v=hvIBURPwtXw
  5. Jan 8, 2014 at 11:16 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    The 2 to 3 mpg were based on the 2014 specs 4x4 automatic. The only difference was the v6 got 2 less mpg city and one less combined. www.toyota.com
  6. Jan 8, 2014 at 11:34 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Not saying you had to get the v6, there is always the 2.4L
  7. Jan 9, 2014 at 4:14 AM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    I think that initial cost probably plays a large part. I'm sure that the 2.7 is a lot cheaper to manufacture and toyota recognizes that not everyone needs the v6 and so offers the 2.7 and passes the savings on to the consumer.
  8. Jan 9, 2014 at 6:34 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    Its also a simpler engine, easier to work on, reduced maintenance cost...etc
    I also like that the first Toyota pickups were 4 cyl, and they continue this tradition as the only 4 cyl 4x4 pickup
  9. Jan 9, 2014 at 8:05 AM
    tooter
    Greg
    Los Angeles
    I'm a bottom feeder who always goes for the cheapest model with the fewest options because it still utilizes exactly the same Toyota mechanical engineering as the most expensive model. It's just smaller and has less doodads. My new 2012 was $19k out the door. As a cheap economical reliable bare bones work service vehicle, Toyotas are unsurpassed. :)
  10. Jan 9, 2014 at 9:18 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I like looking in the engine bay and being able to see the ground and almost all sides of the engine. Not so intimidating when I have to break out the tools to fix or repair parts.
  11. Jan 9, 2014 at 10:05 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    The v6 was only a grand more on the website. I'm sure there different at the dealers.
  12. Jan 9, 2014 at 10:26 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    I never said that's the real price. That was just what I saw.
  13. Jan 9, 2014 at 10:28 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Dad has an 09 2.7L manual. Definitely see the reason for having that motor in their lineup. And when you said that people can just get the 2.4, they don't offer that in any 6-lug option.
  14. Jan 9, 2014 at 10:41 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    2.4 in a 2nd gen??
  15. Jan 9, 2014 at 5:24 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Can't hate on the 2.7. Its such a great option for our trucks. For the guy that only tows a couple of wheelers to his riding spot and drives home from college every other weekend. Not right for everyone that's for sure however the reliability out of these 4 banngers is arguably better then any other trucks power plant. With all the stuff i have done to my truck i would like to see a v6 taco get 23.5 - 25 mpg's on the highway. 2.7's UNITE!
  16. Jan 9, 2014 at 6:32 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I think a lot of guys are taking your question as an insult. But I will try to answer it more as a question of business strategy on Toyota's part. The smaller engine option are always more popular with fleet customers. Let's take orkin for example b/c they run the reg cab 4 cyl as their work trucks.
    Let's say orkin is going to purchase 300 trucks for their fleet. @ $1000 per truck if only the 6 cyl was offered that's $300,000 they just saved when purchasing their fleet. Plus the 4 cyl requires less maintenance than the 6 cyl. Plus the 4cyl gets better fuel economy. So all this is factored into their business plan.
    All the manufacturers have a base engine in their business plan for just this reason. To us as private owners it's only $20 a month but to a business it can mean big bucks. Most of the guys with 4 bangers on here are in my estimation either really loyal to Yota 4cyls or Cheap asses. No offense intended to anyone b/c I fall into both categories.
  17. Jan 9, 2014 at 6:34 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    In stock configuration the 2.7 vs the 3.4 power/displacement/weight/fuel efficiency ratio makes the 3.4 the best option if you only care about power and displacement. when you factor it all in, the 2.7 is a banging little motor.
  18. Jan 9, 2014 at 6:41 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I know one reason...
    If you're comparing models with manual transmissions, the four cylinder gets anywhere from 6-10 mpg better than the V6 at freeway speeds, depending on configuration. Ever drive a six speed at 75 mph? Turning four litres at 2700 rpm is not only noisy, it'll try to burn 7 gallons in a hundred miles. Six gallons if the wind is at your back. With the four cylinder, even with four wheel drive, I can do a hundred miles on five gallons or less when cruising at that speed.
    If Toyota would have used a better transmission, I might have kept that truck.
  19. Jan 9, 2014 at 9:54 PM
    gray223
    SE Missouri
    2014 Tundra Limited
  20. Jan 9, 2014 at 10:24 PM
    tooter
    Greg
    Los Angeles
    Cheap ass here. ;)
    I chose the base 2.7 2x4 5 lug 5 speed manual as my fleet vehicle even though my fleet is only one vehicle.
