REASON FOR THE 2.7L...??
Discussion in '4 Cylinder' started by gray223, Jan 8, 2014.
  1. Jan 22, 2014 at 7:50 PM
    #101
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Hate to say it but I have a 2.7. At the time, I bought it because I was compensating for my abnormally huge penis! There I said it...feels so liberating!;)
  2. Jan 23, 2014 at 4:51 AM
    #102
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    That's the point I was trying to make.
  3. Jan 23, 2014 at 5:13 AM
    #103
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I was agreeing with you. Maybe I should've worded the beginning different. Haha but yeah and Kase if you are referring more weight to the difference in having a 2.7 or 4.0 then I'd say there's nothing behind that statement. Not sure on motor weights exactly but I'm sure that 4.0 doesn't weigh more then #100 more. That would be like taking your truck, throwing a couple sand bags in it, and magically turning it into a towing rig. Well .... I guess nothing's impossible. ;)
  4. Jan 23, 2014 at 5:26 AM
    #104
    Boone
    Boone, NC
    Airbags deployed
    I wasn't sure if I was clear enough after re-reading my first post. Not enough coffee yet.:pccoffee:
  5. Jan 23, 2014 at 6:09 AM
    #105
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Just do the front of an X vs the front weight of a base extra cab. 3850 for a 2013 X and 3615 for the access cab 2tr 5 spd.
  6. Jan 23, 2014 at 6:34 AM
    #106
    bumpkin1
    bumpkin1 Active Member
    I pulled out a 2010 tundra with my 4 banger in 4L, and I pulled a ranger out of a deep deep ditch. Both times I was on hard ground though. I have seen two F150s with 33" swampers, both with locked diffs, sink all 4 tires down to the frame. Bigger engines does not mean better performance in all situations.
    I think towing is the strong point for the V6. But I also think that a lot of people test drive new 2.7's and come away thinking its a dog, never considering that new engines have to break in. Once I had about 10,000 on the odo, my truck had broken in nicely and was much more peppy than when brand new.
    If you have heavy toys and tow a lot, get the V6. You can't go wrong with either.
  7. Jan 23, 2014 at 9:02 AM
    #107
    woodencanoe
    woodencanoe Member
    Bahhb
    West Coast Canada
    2006 Tacoma, 4 cyl, US vehicle
    bug screen, window guards, Timbrens, extra D rings; brake controller, Hidden Hitch, kayak rack,
    I installed the Timbrens when I had to deliver a Northern Lite camper for a friend. The weight of the camper was a tad more than I figured the truck could handle without something. They worked well on the journey and certainly wouldn't want to have gone without them. Talking with my friends here they all like the Timbrens better than air bags.
    I use the truck for hauling lots of stuff up to the cabin I'm building on a gravel road and it's a nice ride with no sagging in the back.
    My sister just installed air bags in her '13 DC 6 cyl that has the tow package so I'll see how she likes them. Timbrens were easy to install without a hoist or jack.
  8. Jan 23, 2014 at 9:13 AM
    #108
    81shark
    81shark Well-Known Member
    for me, it was a budget issue. i could afford to spend X amount. i wanted the tacoma access cab. only the base 4x2 fit the budget at that point in time. my choices were reg cab 4x4 or access 4x2. i took the space.
    i could upgrade to a v6 and 4x4 now if i wanted, but no need to take on debt or drain the bank account.
  9. Jan 23, 2014 at 11:02 AM
    #109
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah that ain't enough difference to mean much in the mud. That must be engine and trans weight difference and a bunch of little things that go along with them. Yes power is a helpful thing sometimes in mud but if you are geared correctly with whatever size tire you run, use 4lo for what it is intended for (massive amounts of torque) and run the right tires then you can lead and keep up with anyone else, no matter what size motor they have
  10. Jan 23, 2014 at 11:58 AM
    #110
    Phil Dammit
    Your Mom
    Tempe, Arizona
  11. Jan 23, 2014 at 2:49 PM
    #111
    Frkypunk
    Timmy
    Woods of P.A.
    Cool video and it's neat to see a Subaru with front and rear axle swap. Or do you think it's just a Subaru body on a older Toyota truck frame?
  12. Jan 23, 2014 at 3:56 PM
    #112
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    hahaha that thing is badass!!! I need a pos like that as a dedicated crawler! That thing is pimp shit!!! and yeah that shows my point. It took only the motor running to make enough power to do that. haha
  13. Jan 24, 2014 at 6:57 PM
    #113
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    Thanks for the input. I think that's the route I'm going to go.
  14. Jan 27, 2014 at 12:51 PM
    #114
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    Bulletproof.
  15. Jan 27, 2014 at 12:57 PM
    #115
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I think it's still a suby frame, has a boxer motor in it. He does have a cage all throughout too, if you look closley. It's fucking rad because all he has to do is roll up the windows if it starts raining.
    Yeah, that legacy wagon is tits, makes me wish I picked up one of those instead of my sammi.
  16. Jan 28, 2014 at 8:21 AM
    #116
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah no shit. That wagon is so uncommon that even if it was the gayest car alive on the street, it would be the pimpest thing off-road. Sammi on the other hand .......... Gay either way :D
  17. Jan 28, 2014 at 8:23 AM
    #117
    Phil Dammit
    Your Mom
    Tempe, Arizona
    :rimshot: DOUCHE
    Wagons actually pretty common, my parents had the predecessor
  18. Jan 28, 2014 at 8:40 AM
    #118
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha ;)
    And YES!!!! Air high five for your parents!
  19. Jan 28, 2014 at 8:40 AM
    #119
    Boone
    Boone, NC
    Airbags deployed
    See at least four or five a day here.
  20. Jan 28, 2014 at 8:48 AM
    #120
    Phil Dammit
    Your Mom
    Tempe, Arizona
    My dad drove this after he sold his chevy
    My mom and pop's went to buy a justy at the dealer a few weeks later and ended up with this instead. My mom fell in love at first glance. 5spd, turbo, 4door variant, locking transfer 50/50 split. Car was dope. Pretty sure the RX was the predecessor to the Impreza. And they wonder why my favorite car is an Impreza or that my truck looks like a subaru.
