Reasons for Lifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTB Tacoma, Jun 8, 2020.
  1. Jun 8, 2020 at 5:03 PM
    JTB Tacoma
    JTB Tacoma [OP] Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    Mind you, this is coming from someone brand new to the Tacoma world.
    Obviously, if you are taking your truck off-road, especially if you are going into rough terrain, having your truck lifted for more clearance and/or larger tires is important. And some folks are going to do it for the looks of it, even if they have no plans of taking the truck off of pavement.
    My question - is there any other benefits of increasing the lift on your Tacoma, aside from what I just stated? (Clearance, bigger tires, looks) Are there other ride/performance benefits that one can gain from a slight increase in height?
    photogr4x4, davidstacoma and RobP62 like this.
  2. Jun 8, 2020 at 5:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Fat chicks cant jump
  3. Jun 8, 2020 at 5:11 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Compensation. @RobP62 wont let me lie
  4. Jun 8, 2020 at 5:17 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Welcome.
    There must be some engineering benefit for Toyota to lift their 4x4 and Prerunner trucks. 2nd gens, 1st gen, and the Pick up aka 6 lug trucks. Are already lifted by Toyota when compared to the 5 lug trucks. Reminds me of a factory drop bracket lift. The transfer case and front diff wouldn't otherwise fit.
  5. Jun 8, 2020 at 5:17 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I can't think of any.
  6. Jun 8, 2020 at 5:18 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Lift for gains
    tinker_troy likes this.
  7. Jun 8, 2020 at 5:26 PM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    Height, in and of itself doesn't improve anything besides the benefits you stated, but usually with after market struts springs and shocks they have better performance ie; ride quality. Lifting a truck, and putting bigger tires on it lowers your over all gear ratio so that you have less power and makes your truck less fuel efficient, it's higher. But it sure does look awesome! If you use your tacoma for a lot of highway driving and little to no off reading I wouldn't lift it imho.
    koditten likes this.
  8. Jun 8, 2020 at 5:40 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    There’s really no pros. Lifting trucks has negative effects only. Depending on how much lift you’re doing you can justify it because the pros of bigger tires can outweight the cons if you’re off-roading. But that’s about it really. If you’re on the pavement all the time and do minor stuff on dirt you’re much better off keeping the suspension stock and running better tires that can handle shitty weather and light duty wheeling
    Crosis and winkel like this.
  9. Jun 8, 2020 at 5:55 PM
    Taco Wake
    Taco Wake Well-Known Member
    South Carolina
    Don't know if you consider snow off-road, but a lifted truck can be much better in snow. I used to have a BMW that was pretty low to the ground and the front lip/valence would act as plow going through deep snow. If it was just a small drift I could push through with speed, but bigger drifts or deep snow everywhere would get me stuck.
    davidstacoma likes this.
  10. Jun 8, 2020 at 6:45 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Some people like being higher off the ground for visibility driving. Sometimes it affords me a parking spot that other's can't clear (without being a douche on parking). When the road floods, I like the little extra clearance I have when going through it. Paired with my sliders, it helps avoid the door dings. Sometimes if you have something long laying in the bed, it'll help with clearance on those departure angles. I deal with that sometimes with my steep driveway. That's about all I can think of.
  11. Jun 8, 2020 at 6:50 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Call it a "suspension upgrade" and you'll keep the trolls away. Maybe.
    Justanotherhemi likes this.
  12. Jun 8, 2020 at 6:51 PM
    Justanotherhemi
    Rick James
    Hi Roberto.
    RobP62[QUOTED] likes this.
  13. Jun 8, 2020 at 6:53 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That's the story of my life Brother :anonymous:
  14. Jun 8, 2020 at 6:57 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hola Jaime.
  15. Jun 8, 2020 at 7:00 PM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Handling really, on and off road, and better performance from your suspension. Some suspension companies are known for high speed and firm handling (Icon), and other companies are known for softer/cushier handling that can absorbs bumps a lot better (OME, Fox, King I think?). I know my truck is a truck and it's gonna feel like a truck but the stock suspension on the TRD off roads is extremely jarring over the most minute bumps. My goal is to achieve better handling and comfort on dirt, asphalt, snow/ice ridges our town is known to get in the winter, rocks etc. However your three main points are mostly correct; more clearance, rugged good looks :rofl:, but a lift won't generally let you achieve larger tires unless you have a body lift on. There's too many other factors like wheel specs, fender shape, cab mount etc that will dictate your ability to fit bigger tires.
  16. Jun 8, 2020 at 7:01 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    NO benefits at all,in fact lifting causing a bunch of problems with vibes in most Tacoma's.
    Crosis and koditten like this.
  17. Jun 8, 2020 at 7:32 PM
    JTB Tacoma
    Central NJ
    Since, back in the day, I used to drive a Nissan 300Z, I know that 'snow plow' experience all too well.
