Reasons for main breaker tripping?
Discussion in 'Garage / Workshop' started by kingston73, Jul 22, 2016.
  1. Jul 22, 2016 at 6:34 PM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    We have only lived in our house since November so I'm still learning things about it. We have a somewhat unusual setup with our main breaker on a pole outside the house, just below the meter. Inside the house we have the standard panel with another main and then the other assorted typical breakers. We have electric water, and electric dryer, and two heating/cooling units (1 upstairs and 1 in the basement)
    From November until just now in July everything has worked fine, but just this week twice now our main outside breaker has tripped. Both times it was very hot (mid to high 90's and high humidity) and both times at least 1 of the ac's and the dryer were running.
    From what I've been reading it seems like either we need an electrician to check our breakers and/or an ac tech to check the central air units. Where would you start? Thoughts and ideas are welcome, this is the first time I've ever had central air and also the first time I've lived in a place were the main was outside.
  2. Jul 22, 2016 at 6:37 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    AC uses a lot of juice. You are probably exceeding the amperage draw of the breaker outside. Possibly the breaker itself need replacing, or if the rest of your system can handle it, like the drop wires and breaker panel in the house, you can put a bigger breaker in outside.
  3. Jul 22, 2016 at 6:41 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I'd go with the electrician first.
    I've seen breakers wear out so they tripped when they shouldn't.
  4. Jul 24, 2016 at 6:49 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    What is the main rated for? Can't say that I've ever seen a main trip before. To me that sounds like a bad main or wiring near the main. If it was an a/c system fault then their individual breakers would most likely be tripping.
  5. Jul 24, 2016 at 8:40 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    It's a 100 amp system. The first time it happened an electrician came out and took a quick look at things but didn't charge me anything and didn't look at things in detail.
    My inside panels isn't great, it's a mix of parts and it looks like whoever put it in used whatever was in their bag instead of using all matching pieces. Not sure if that has anything to do with the issue or not.
  6. Jul 24, 2016 at 9:03 AM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    It sounds like it's tripping because it's old and because of the conditions - hot outside temp and multiple larger appliances running. Breakers have a thermal overload which can cause them to trip at a load of over 80% of their rating for a prolonged period. So 80 amps of load over a long period (60 minutes or more) could trip a 100A breaker.
    If the circuit breaker is old (>25 years), the thermal link might be worn down and become more sensitive especially in very hot ambient conditions. If the main was in direct sunlight at the time that could have made it worse. So even if the dryer and AC and a few smaller lighting or outlet loads combined were pulling only 60 amps, it's possible the breaker is overheating and false-tripping.
    Don't try to change out the main breaker yourself, though. The incoming power from the utility pole can't be turned off. Electricians have professional training and insurance, let them handle the risk.
  7. Jul 24, 2016 at 9:08 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Thanks for the info. I'm not sure how old the outside breaker is, the original house was from 1927 so things have been here a while. There's no way to tell by looking how old it is, is there?
  8. Jul 24, 2016 at 12:11 PM
    cosmicfires
    David
    Everett, WA
    Maybe, if it's a Pushmatic brand it's old, I had a house with a pushmatic breaker panel, they kept dying, it was hard to find new ones. Sold the house. The buyer's inspector said the panel was a POS, I agreed.
    The only way to shut off power to the main panel is to remove the meter, you shouldn't do that yourself. The power company puts a seal on it so they can tell if it's been tampered with.
  9. Jul 24, 2016 at 12:31 PM
    gliderpilot
    gliderpilot Well-Known Member
    Tex (Mike)
    Central Texas
    19 Tacoma TRD Off-Road 4x4
    I totally agree with this gentleman. As a retired EE and a former Professional Home Inspector in Texas I have to say that a 100A panel is somewhat puny these days. Definitely call an electrician and have him evaluate what upgrades might be needed to handle your electrical/power needs. Don't know how old the house is, but you might need a 200A main breaker, an upgraded subpanel with new breakers, some obvious wiring upgrades, etc.. As the man said ....don't try to do this yourself!!
    File IFR likes this.
  10. Aug 5, 2016 at 6:14 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    ^^This
    ^^ This too
    I'd have the electrician check to see if the lugs of the SER cable are of the right torque. A fairly loose connection will heat up and trip a breaker. Every year I remove the panel covers and tighten down every breaker in my panels, I'm always surprised as to how loose some get over time with expansion/contraction from the heat it generates.
  11. Aug 6, 2016 at 2:17 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Could very well be a bunch of things
    100 amp breaker to many Motors all starting at the same time inrush current draw is to high
    Then breakers tend to trip always far from the load The main breaker every time.
    Could be effected by a local Brown out effect due to the high AC use.
    As the grid voltage drops the amps needed to start motors rise
    I grew up with a 60 Amp service tube and knob wiring.
    Living in Mass it could get expensive if you need to upgrade the box
