Rebuild or buy new ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HUNTN247, Dec 21, 2022.
  1. Dec 21, 2022 at 9:29 PM
    HUNTN247
    HUNTN247 [OP] Member
    Greg
    2010 Toyota Tacoma Regular Cab
    I bought a 2010 Tacoma 4X4 with 268000 on it. Its my first Toyota truck so I am learning as I go. #3 cylinder is losing compression and its gonna need some work soon. My question is do I buy a new engine or rebuild what I have?? So many options it makes me dizzy. Thanks for the help!
  2. Dec 21, 2022 at 9:35 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Buy a used engine and drop in in. 4.0s are not too bad to locate
    goforbroke123 likes this.
  3. Dec 21, 2022 at 9:38 PM
    HUNTN247
    Greg
    2.7 are $$. Must be a popular engine
  4. Dec 21, 2022 at 10:02 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Durable, so not a lot on the market as well.
    Love mine..
  5. Dec 21, 2022 at 10:20 PM
    texan626
    texan626 Active Member
    Rick
    Waco Texas
    2000 2dr SR5 2.4 automatic
    Sounds like you/someone has done a bit of work to determine that #3 has lost (some) compression. If it's zero or close, might be just a burnt valve. Any other cylinders low or just that one? What is the compression reading on it and the others (if you know)? I bought my Tacoma about 2 years ago and #1 was misfiring/dead (265k). No compression on #1. Had a burnt valve. Did a valve job (myself) and runs like new now. Might want to see if you might have a similar problem. Valve job took some time/work and you might be able to buy a replacement engine for the same/less money as a valve job. I never considered an engine as the rest of my engine was fine. I would spend just a bit more time on the diagnosis and then do some pricing to see what makes sense to you once you know what the actual problem is.
  6. Dec 22, 2022 at 1:10 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Ah 4 banger. Great motor. There is a reason they are expensive but worth it
  7. Dec 22, 2022 at 5:57 PM
    HUNTN247
    Greg
    #3 is about 5 pounds off 1 2 and 4. Ive been driving it and it does this real hard shutter and the check engine light starts blinking. You can turn engine off and crank it and it runs fine. Check engine light stays on all the time. Code reader says #3 misfire. Thanks for the info on the valves. The gas mileage sucks!!!! Gonna limp it through deer season and tear into in Febuary.
  8. Dec 22, 2022 at 5:58 PM
    HUNTN247
    Greg
    130 132 121 133
  9. Dec 22, 2022 at 6:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That's not a big enough difference in compression to really matter. They all seem a little on the low side but hard to tell without standing next to you while you do the compression test
    Try moving the #3 ign coil to a different cylinder and see if the code follows
    landphil, MarX and Pabloeeto like this.
  10. Dec 22, 2022 at 6:01 PM
    HUNTN247
    Greg
    Any clue whats affecting the mpg?
  11. Dec 22, 2022 at 6:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Probably the misfire
    MarX likes this.
  12. Dec 22, 2022 at 6:09 PM
    HUNTN247
    Greg
    ok thanks for the info!!!
  13. Dec 22, 2022 at 7:57 PM
    texan626
    Rick
    Waco Texas
    2.7 liter 2TR-FE Engine.
    Compression Pressure: 178 psi.
    Minimum Pressure: 128 psi.
    Difference Between Cylinders: 10 psi.
    Appears your compression numbers may be getting a bit low based on what you posted. Delta is on the edge of not being good. Did you have all the plugs out when cranking over the engine for the compression check? And the battery was cranking the starter at the normal speed (not slow)? If not, remove all the plugs and then run the compression test again on each cylinder. It's important to know what the compression actually is best that you can. I didn't see it in your post but is your CEL flashing/staying on constantly when the engine is running? If so, which is it? Flashing or staying on constantly? Or maybe it's off? Flashing constantly typically means a dead cylinder which could be a lack of compression, low/no spark or low/no fuel getting to that cylinder.
  14. Dec 22, 2022 at 8:05 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    before you go replacing the engine, change all of your spark plugs with ngk or denso units, if that doesnt do it, take the coil pack from #3 and swap it with a known good cylinder and see if the problem follows, it could just be a coil pack or ignition related.
    some fuel injector cleaner wont hurt either.
  15. Dec 23, 2022 at 8:00 PM
    HUNTN247
    Greg
    Check engine light stays on. It doesnt happen everytime but when you pull a steep hill and gear down from 5th to 4th the engine light will start flashing. You can pull over turn it off restart and it runs better. Check engine code is a #3 misfire.
  16. Dec 23, 2022 at 8:01 PM
    ABA180
    East Bridgewater MA
    I'd suspect a coil pack, though I'm no expert re internals of the engine. This sounds similar to a car I had long ago when you mentioned the restart and it getting the flashing light under load, coil pack solved it
  17. Dec 23, 2022 at 8:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Move the #3 coil to a different cylinder and see if the code follows
    landphil likes this.
  18. Dec 23, 2022 at 8:32 PM
    HUNTN247
    Greg
    will do as soon as we get put from under this artic deep freeze ! I live in North Alabama it was 6 here today!!
  19. Dec 23, 2022 at 8:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Replace the valve cover and spark plug tube gaskets then new plugs and coils. Good luck
